Proposal Ring - Part 2
Lynntoh
Without side diamonds, for 18k white gold would be $550. $950 for platinum settings
Thanks a lot! Just wanted to get a gauge of the price range in case they quote me something that is significantly different.
Btw, any one here can advise on the price range for the setting? My girlfriend wants something simple, so it is likely that I will get one that is without any side diamonds
not advisable to get a carat which ends with 0.X. If the diamond is chipped, the value significantly drops.
Try to bargain for plain setting to be at $500. It can be done *winks*
red_devilz
Haha. I'm going for a setting with side diamonds. Does JP have any guidelines, say >5 side diamonds, we must top up?
Lurker_13
Nope not that I know of... but setting with side diamonds will definitely cost alittle more compare to plain settings.
Lurker_13
My SO's ring setting has abt 8 diamonds on each side... but I can't remember how much the setting cost me. But I definitely dun recall JP charge me more bec' > 5 diamonds...:s13:
Edit: mine is customised pave setting @ $1,300 2 years ago. Here's a 3D render pic done by JP
Symbol
Nice ring! Can I ask how much is this including the setting?
From what I gather, with a budget of around 6k, I should be able to get a stone that is approximately 0.6c, VS1/2, E/F?
Heading to JP next week, and this has been a really informative thread!
haha Thats not my ring bro. I got a Brellia. :s13:
I just screenshot from the video.. hahhaha
whitetiger89
With a 5.5k budget for the stone only, you can get a super ideal 0.6ct, vs1, F color. Just spoke with Samuel from JP today about this :)
The super ideal only has the round diamonds? Was just looking at some of JP's octagon diamonds and I might consider those too.
Will there be a significant price difference?
red_devilz
Yes. Super ideals are only round. For octagons, I believe they command a significant price premium :)
vabian
guys, which is more bang for bucks? headache :s22:
Brellia from JP,
0.967 D VVS2 $16,200
0.954 F VVS2 $13,600
0.94 E VS1 $13,200
0.932 G VVS1 $11,600
Lynntoh
Brellia from JP,
0.94 E VS1 $13,200
if budget is not a concern, I propose 0.967 D VVS2. The best bang for bucks would be 0.94 E VS1. I personally has higher expectations for colour instead of clarity.
red_devilz
Hi, just received my scopes. Would like some feedback if possible. Is there too much light leakages from the white spots? I'm a noob at judging these scopes so it'd be good to get some feedback. THanks!
Lynntoh
Seems like super ideal scopes all look similar Haha. Shall not be too paranoid then :)
Yah if you want minimum light leakage gotta go for solasfera with a more premium pricing =)
But though there seems to be alot of light leakage, the super ideal still sparkles in my opinions. My colleagues have commented that it looks very bright and even my boss also noticed it.
