Proposal Ring - Part 2
ssyahaha
Split Shank Halo Setting E-Ring
htt p://imgur.com/loEpe2U
htt p://imgur.com/Lwyy5qn
anyone can help upload too! I chose split shank halo setting too but yeah never wear it to work hahaha
fir3bon3
Uploaded! Nice ring :)
lovedisorder
Hi all..
Just to share my experience..
I have been wearing my 0.57 carats super ideal cut from Jann Paul for two months. My setting is the Tiffany and co plain setting with 6 prongs. Somehow I find my diamond not as bling as I thought of it to be. Sometimes it doesn't reflect much light. I'm not sure if it is due to the 6 prongs blocking the arrows or what. I see other rings (colleagues, friends) and it reflects light more than mine in the same setting.
I'm a bit disappointed and their rings are not from Jann Paul. I'm thinking of upgrading to a bigger gem but am torn between the different settings. A 4 prong with side diamonds seem to reflect the most light thus making it more bling? Or should I go for a halo? The problem with halo is that I'm not sure if it will block the diamond from sideways too since the side diamonds surround it?
Will greatly appreciate your replies! Thanks!
Lynntoh
Hi all..
Try to clean the ring with mama lemon and toothbrush to brush away the dirt accumulates on the diamond. Casey told me once you find the diamond looking blurish then its time to clean. My setting is also a 6prong
Sent from Samsung SM-N920I using GAGT
1000smiles
Hi all..
By right the number of prongs won't affect the bling of the diamond. The light return goes into the diamond from the top and gets reflected back out which is what makes the diamond bling. For a good cut, even if you block the sides of the diamond completely, it will still be very bling. Yours is a Super ideal cut so it should be maximum bling already. Try cleaning your ring. It should do the trick.
dustyRoom
yes must clean regularly, shine level will go back to day 1's
Sent from Earth using GAGT
ssyahaha
Wow its very unbelievable that the whole ring w 0.47 carat plus setting only cost $3.8k... my former 0.46carat w plain setting alrdy $4k. Lucky as in?
Lucky as in the diamond was a good super ideal with the hca score within 1.2! Triple excellent. Really? hmm I just told her what I wanted but yes that was the price the fiance' paid hahaha not kidding at all!
