U can choose settings from their current selection but your ring will be newly crafted with your chosen diamond. So waiting time is about 4 weeks if no customisation.Thanks! do they have pre-set ones?
Calling for scyllahello,
anyone bought a 1.01 cart with settings from Jannpual? care to share the price and diamond parameters?
Here you go.. Nice! Simple with side diamonds hehehe. Like the tapered part!
Thanks.
Not really customised, off from their shelve.
The customise design i hope is not feasible. So just choose from their shelve.
IKR! super chio~ I think we are most or less settled with this. We will wait for the Halo render first.![]()
I got mine 0.61 E vs1 $5950 for the diamond itself. here is a photo of the 0.61 on my finger for you to agar the size =)
Sent from Samsung SM-N920I using GAGT
Nothing is too big ba. 0.6 to 0.7 should be okay, consider a little above average as compared to others on the streets. It really depends how much you wana spend on her. if cannot hit your budget, maybe you can consider taking F colour or VS2, it's good enough already. who knows u can get a little bigger than 0.6 if u take vs2 with that budget.![]()
I got a 0.57ct,D VS2 with side diamonds and halo setting for $6250. Just to give you an idea of how much 6k can take you up to.
so am i right to say that if the colour & VS is lower , the bigger the stone i can buy ? like bigger carat size.
Sorry i'm still new here, need guidance from all senseis![]()
yeah the finger size is just about right .. ahh good price u got there.. where u bought it from ?
Can like that say la, you're sacrificing the colour and clarity for the size lor. Can always make an appointment with JP to learn more! It was very insightful after sitting thru the 'lesson' hahaha
thanks bro for sharing your experience ! so does the side diamonds & halo setting is included in your price right ?![]()
hahaha. Its so much better than my old diamond ring. Wished my hubby knew about JP earlier.. haix..
