hihi, I'm new here! What is the reasonable price for a 0.6 carat, Colour E, Clarity VS2. Excellent Cut. Hape and cutting style - brilliant round. GIA cert. Thanks!!![]()
My 0.63 carat, F, Vvs2, triple excellent, faint fluoresence, round, GIA, i got for about $5k, I also got multiple small diamonds and the sides to like tiffany bead setting.
what is the difference between excellent cut and all
those triple excellent.. super ideal etc? I'm so confused. haa
GIA got grade Symmetry, Cut, Polish. When these 3 are excellent it means triple excellent. Some could be excellent/good/poor or good/good/excellent. And note that the maximum grade GIA will give is excellent.
However, not all GIA triple excellent cuts have nice hearts and arrows.
Some grading certifications include Super Ideal Cut to indicate that the diamond has nice hearts and arrows. All decently cut diamonds does have some form of hearts and arrows but just take note GIA graded excellent in symmetry and cut are more likely to have nicer ones.
Ultimately, you have to see the scope to truly believe it.
The HCA calculator is just the first step in buying a diamond.. The best is still to use the other scopes. Like what zakkieez has posted before, a diamond can have a very good HCA score but still have light leakages and unsymmetrical hearts and arrows. To know what you're really buying, you should use the HCA calculator AND the other scopes..![]()
Hi all,
Anyone can advise on where I can go to get a diamond unmount from an old,polished and remount onto a new band?
many thanks.
Hmm.. is 3.6k expensive for my specs? Pls tell me it's not. haha.
0.6c, E, VS2, Excellent cut and symmetry, Very good polish, medium blue fluorescence, brilliant round, GIA.
Forget about those big jewellery retailers such as Lee Hwa. Most private jewelers can customize ring design and naturally they can un-mount and re-mount the diamond for you. Most importantly, start looking at their ring collections first to see you if you like it. Frankly, every designer got their own style and flair. You may want to approach JP or Ling Jewellery for your new band. Nevertheless, I will prefer Ling jewellery in my personal opinion.
jiak lat. Would not buy this. Sorry to say...
No prob. Personally I don't mind fluorescene effects. =)
its finally time to get a proposal ring. I guess we're leaning more towards a customised ring.. i've heard raves about JP pretty often and i understand they only do appointments.
before i book a session with them, any other recommendations for jewellers who provide similar services as JP at the same price point?
i don't think there is any jeweller in Singapore that can match jannpaul and provide the same service![]()
