Hi just curious why is everyone recommending Jane Paul ring?
Any specific reason and where is the shop located at?
Value for money and his diamonds are top notch and sparkly. Plus they give very good service too. Located at outside Far East Shopping centre behind wheelock place. Its called House of Hung.
Hmm if I want to custom made what is the budget I Shld be looking at?
Hi, any bro can comment on this GIA Graded Round Diamond - 0.64 Carat, E Color, VVS2 Clarity (#6107834479) in Diamonds | Excel Diamonds ?
The HCA I calculated is 1.3.
As in we would not know without looking at it through an ASET scope right?
Alright thanks. Sent an email to request idealscope and ASET scope data. Will post here when i get it for further advice.![]()
I used the above chart for my diamond.
Basically, IMHO, need to ensure GIA certify Excellent Cut then take a look at the crown and pavilion angle combinations chart above. Those with bold are the best HnA examples.
Of cos the best is still the scopes and such so request for them if possible.
Wheres jp situated? Cant find the shop. Isit in another shop?
It's hard to say without more info about the diamonds.. like is it
1. Triple Excellent?
2. Got fluorescence?
3. HCA Score
4. Most importantly, does it have light leakages under the Ideal/Aset scope
5. Symmetrical hearts and arrows?
You can save on the price.. but you don't want to sacrifice on the quality of the diamond either..
Thank you so much for the advice.
I'm not that knowledgable when it comes to Diamonds, therefore can I ask you what does each aspect of what you've mentioned mean?
1) Triple Excellent: Does it mean there are different grade to this? Is it related to any of the 4Cs?
2) Fluorescence: Is it good to have this or no?
3) HCA Score: How does the score work? Higher the better or...?
4) Light leakages means it's not a good diamond?
5) Hearts/Arrows: Does it mean having this shapes increase the quality or price of the diamond?
Appreciate any advice on this as I'm rather new to diamonds.
If I choose to custom made the ring how long will if take?
Both Aset and Hearts is important for analyzing modified cuts like Brellia
Aset > Ideal
Reds shows the whites
Greens shows the greys
Blue shows the blacks
White shows the leakage, messiness, milkyness
Scrolling the video to 2:47 you can see the normal cushion and the Brellia H&A.
Looking at where the reds are will get you the brightness, then the greens at the corners look grey? and the arrows look black. What this means is that when you set the Cushion Brellia up, the ring claws goes over the 4 green corners, allowing the Brellia to look extremely brightI don't think anyone noticed this before
The arrows(blue) on the aset act like mirrors to reflect fire, the reds get good amount of dispersion also (sparkes/fire) the greens only show at certain angles
If you see the normal cushion at the white regions are very dead in fire and the greens only show when the diamond gets tilted..
JP has another video about Hearts... can't seem to find it now![]()
