Hello diamond gurus! Would like your opinions on the rock I've chosen. Should I be worried about the inclusions? There seems to be a lot but given that its a VS2, it should be ok?
These are the kind of feathers, that cut through the girdle that should be avoided, yours is surface which is entirely fine. But there are also feathers forming close to cavities on girdle surface which wont cut through can also pose a threat of chipping and you can't tell on cert and must see with magnification but those are usually in SI range and below.
Also inclusions come in various colors like black clouds, black pinpoints, black crystals that might be more obvious, but you must see that for yourself. If those are white then of course no problem, request to see the inclusions?
