Mind sharing you guys budget for ring at JP? I see some quote till 5-7k...
My gf don't want waste money on ring and ask for sub-3k, think JP will entertain us?
They will entertain anyone, regardless of 1k or 100k
here you go
Just wondering how many carats is your diamond? And perhaps you can share with us why you had chosen a 6 prong setting?
here you go
Wow, it's really pretty! I'm thinking if I should choose the 6 prong and am afraid it'll make my 0.55c smaller![]()
JP has the 4 prong version as a standard setting, which you can ask them to show you. Personally, I would have also chosen 4 prongs for a smaller stone since the exposed girdle area is smaller and there is less risk of chipping.
But don't worry too much about whether a 6 prong will dwarf the center stone, because there are other parts of the ring which can be modified accordingly. E.g. for mine, the band is slightly thicker than usual so visually it looks matched to the center stone. The JP salespeople should be able to advise you on what works best for your specific diamond.
here you go
Thanks for sharing this! My setting is exactly the same as yours cept it's 4 prongs and my dream wedding band is also a channel set half eternity.
My stone is much smaller than yours tho! So i probably have to make the channel set stones smaller as well to be proportionate?
May I ask what's the carat weight of your individual diamonds in the wedding band? If i don't remember wrongly your 1.1c is also a G colour like mine, did you request for G coloured stones in your wedding band as well? I am afraid higher coloured stones may make the G colour obvious..
Sorry for all the questions!
anyone got their wedding bands from JP as well?
I just successfully proposed!!Thank you all for the help and advice.
How do I upload the pics here?
