Proposal Ring - Part 3
anizee
The left most heart at 9 o’clock is smaller than the rest. The top right 1 o’clock arrow seems slightly broken. Other than that the rest is ok. Only some minor digging on the girdles. Overall its more of a Ideal than Super Ideal cut.
How about the ASET and proportions?
This is all the info I have, buying it online for about 5.1k SGD.. Thinking if it is a good deal.
anizee
Found another deal.. 0.71, G, VS1 for 5k SGD + tax + local setting at HOH or Ling Jewellery about 1k should still be about 6.5 k or less. Think pricing is quite competitive, any of you guys can recommend? ASET scopes below.
gold_eagle36
Is that aset consider as black background? Meaning the redder the less intense.
The red centre is less intense
anizee
No idea what Black background means, the image is not as sharp as the scopes from JP though. They're from Whiteflash so I think the diamond should still be of high quality?
Lydia.Tan
ASET on black background got difference! Can play cheat wan
Dufasleong
Hi, how does this diamond look?
0.34C, D color, VS1, Super Ideal Cut
Anything I should look out for or any recommendations?
ht ***://imgur.c om/a/7bljGXs
Sorry unable to add image, please help to take a look?
smileedee12
Hmm saw others' replies and agree on being careful with those on black background.. My 0.72 E VS1 ideal diamond from HOH cost $6200. Although my arrows probably not as straight.. If you're going for a no side diamonds kinda ring setting, I believe their ring setting cost only about $600. If you down the carat and colour from my specs, also can get around 6500 from HOH.. At least they let you see through the scopes and do multiple versions of your ring settings (I'm at version 14 now..)
smileedee12
I think u should down the colour, up the carat lol.. If she has slim fingers u can stop here.. If her fingers are chubbier then better drop to an ideal cut and up the carat even more 😬
Kkeell
Anybody noes how each 0.01 is calculated?or each colour jump?the range like quite big.
How u noe if the price quoted to you is accurate.
Isit really always the case ideal and Super ideal only $200 diff?
KinoChoco
No, it’s by %, not 200. Usually 5-10% I believe. So bigger, more expensive.
ThiamWan
Uploaded for you. Yours is already very high light performing. The rest is see what other 3Cs (carat, color, clarity) you want.
KinoChoco
Lower the color and drop the clarity to VS2 and up the carat. My personal opinion, getting a 0.3x Super ideal D color is a bad idea. A 0.45 ideal, F Color VS2 will beat it hands down anytime.
terrorblade
Agreed with the rest. D Colour is wasted on 0.34ct.
Down the Colour and up the Carat.
What's your gf's ring size?
Dufasleong
Thanks for all the reply! I will take a look again.
Her ring size is 48 (8). I thought it was quite small so i went for higher color.
So do you guys think that at this small caret that a Ideal is better then Super Ideal?
dragonbryan
For me I sacrifies a bit to get a bigger carat. I got Ideal cut instead of super ideal cut. I try to make sure the dimension of the diamond is cut within a certain range then look at it under ASET then would be ok le
terrorblade
An Ideal is never better than a Super Ideal because of the sparkle/light performance. A SIC may not be much more expensive than an Ideal too.
You know your gf best. Does she has any requirements on carat? I personally would think a 0.34ct would appear a little small in proportion to a size 8 finger. My gf is a size 5 and I got her a 0.5ct.
If you want to stay in colourless range, drop the Colour to a F and bring the Carat probably to a 0.5ish ct.
Dufasleong
Thanks for your thoughts! Mind sharing your diamond's specs and price?
Dufasleong
My gf doesn't have any requirements so far, but for myself I would rather not get G color. How high do you think i can go with around 2-2.5k Carot wise?
terrorblade
Possibly a 0.45ct if you're lucky? :s8:
Sounds like your gf is quite understanding down to earth girl.
Bottomline is get the best within your budget and I am sure she will appreciate it no less.
ThiamWan
If can, I will still stick to a Super Ideal. Diamond will look bigger in smaller fingers. Or you can ask JP to superimpose your diamond on your gf hand photo. From there you see if big enough or not
