wint3rnights
- Jun 11, 2014
Hi all,
Can you give me an advice on these diamonds.
www dot whiteflash.com/loose-diamonds/round-cut-loose-diamond-4027054.htm
www dot whiteflash.com/loose-diamonds/round-cut-loose-diamond-4032911.htm
www dot whiteflash.com/loose-diamonds/round-cut-loose-diamond-3997343.htm
why is it when i watched the video, there seems to be a scratch / dots on the diamond.
Also really worried about the quality since we do not see. haha any one has any experience ?
I will go with the 0.8 F VS1. Do not go for the 0.9 one as there is twining wisp which u should avoid.
The video is under magnification so u can definitely see the inclusions. VS1 will be eye clean so you won’t see the inclusions without magnification.
