Proposal Ring - Part 3
Pseudomonas
LOL. Jann would probably hate me for highlighting that. Honestly, my eyes are probably more untrained than yours. I went down to JP once, didn't do their lessons on diamonds because I just wanted a fancy cut design. Maybe cuz I just happened to screen many diamonds over Blue Nile and James Allen recently.
Haha please don't say that. I'm sure they would welcome constructive criticism.
Attached are the images of the Octagon 0.836 G VVS2;
Any concerns that the cert is dated 2 years ago?:o
Thanks everyone! Looking forward to your inputs!
Cashflow202
very nice
can share how much dmg?
rosifiedZ
Possible to get a .7carat diamond in octagon cut for below 3k?
It’s impossible . 3k can only get you 0.3x ~ 0.4x SIC or perhaps a special cut if u drop the other 2Cs. Speical cuts are usually 10-20% higher than the SIC of the same carat.
A 0.7x octagon i would say will cost between 7k to 9k depending on the Cs
Tord__
Thanks alot!
Miltah
Hey, does anyone know if it is possible to reset your wedding band and engagement ring?
Yup it’s possible but if your wife’s wedding band has a full row of diamonds across the band like a ‘full eternity’ then it might not be possible
imTHOR
Went to JP ytd and was quoted 5200 for this loose Solasfera diamond. Need some input from the peeps here!
Measurements: 5.22-5.26x3.24mm
Carat Weight: 0.55 carat
Colour Grade: F
Clarity Grade: VVS1
Polish: Excellent
Symmetry: Excellent
Fluorescence: None
Clarity Characteristic: Feather
GIA Report # 6272626502
freewilly5000
Colour Grade: F
Clarity Grade: VVS1
Polish: Excellent
Symmetry: Excellent
Fluorescence: None
Be sure that the feather is not on the edge or surface, though I'm sure JP already will check that and yours is a VVS1. You got the scopes??
imTHOR
Nope. Just paid a 500 deposit as I am looking around for a 0.46++ diamond tho. Quite new to this subforum. Possible to ask them for scope?
rosifiedZ
Assuming you bought from JP, they will send the scope images to the email you provided, within the next few days or up to two weeks latest. I got mine two days after I made my deposit just two weeks ago
imTHOR
Update: I have gotten the diamond scope? any advice on how can I upload here? Don't think I have enough post to upload URL or image on the forum
