Went to JP the other week actually felt that the Brellia had too much premium to the price compared to a normal cushion diamond (noticeable difference side by side but I don't think one could tell from naked eye on normal lighting conditions). So, I decided to look out online and found that BrianGavin prices were much cheaper than JP's Brellia.
1. General advice on what to look at for Cushion Cuts. I have a few stones from BG and Whiteflash which I would like input on but the site doesnt allow me to post links and images. Any way around this?
2. Where to go to set a the loose diamond if I buy it online? I saw a recommendation for Canary Diamond. How much would a engraved yellow gold setting such as below cost? I have a simple hand engraved setting which I like on Whiteflash.
3. Is it better to just buy the diamond with setting if I know the correct size?
1. Most cushion are not cut to hearts n arrows. Thus the premium at JP. If u can’t see the difference of the distinct facet then u dun need much general advice as most would do.
There is a sale at Brian Gavin now with code june1910 (10% off). Pm me for free shipping.
If u want comments, u can post links as text
2. $600 plain setting from Canary.
If I’m not wrong, whiteflash dun do in-house cushions. So u really only got Brian Gavin to consider
3. I would buy online n set locally as the cost of setting is higher overseas, especially if u not quite sure if finger size. If u do, sure, get ring n stone if the cost is reasonable
