Proposal Ring - Part 3
xxvvvxx
Measurements 5.68 - 5.70 x 3.52 mm
Carat Weight 0.70 carat
Color Grade G
Clarity Grade SI1
Cut Grade Excellent
Depth 61.9 %
Table 55 %
Crown Angle 35.5°
Crown Height 16.0%
Pavilion Angle 40.6°
Pavilion Depth 42.5%
Star Length 55%
Lower Half 75%
Girdle Medium to Slightly Thick, Faceted, 3.5%
Culet None
Polish Excellent
Symmetry Very Good
Fluorescence None
Clarity Characteristics Feather
I was quoted USD2600 for this diamond. Can anyone advice if its worth the price? Or am i over charged?
Miltah
Color Grade G
Clarity Grade SI1
Cut Grade Excellent
Depth 61.9 %
Table 55 %
Crown Angle 35.5°
Crown Height 16.0%
Star Length 55%
Lower Half 75%
Culet None
Polish Excellent
Symmetry Very Good
Fluorescence None
In a word. Yes
It’s not worth
jonleelk
Can i know what's could be a decent price for this diamond?
And is there any sources i can get loose diamonds with decent pricing? Any lobang?
Not all GIA triple excellent are good. Your diamond not even triple excellent.
Cut Grade Excellent
Polish Excellent
Symmetry Very Good
Plus u hit 0.7c high price jump. What is the budget you have in mind?
Good diamonds at a similar price point (G, VS2, US$2500-2600):
https://www.briangavindiamonds.com/.../0.624-g-vs2-round-diamond-ags-c-104104773100
https://www.whiteflash.com/loose-diamonds/round-cut-loose-diamond-4133833.htm
https://www.hpdiamonds.com/en-us/diamonddetail/HPD9116
Miltah
https://www.whiteflash.com/loose-diamonds/round-cut-loose-diamond-4063417.htm
The cheapest 0.7 G SI1 from whiteflash is us$2900.
I would abe careful with a non vetted SI stone with feathers. Where are the feathers?
Yes it’s more ex. But your choice is not even a triple excellent with only VG symmetry.
So if u are happy with non-triple excellent stones, I’m sure there are cheaper ones
U can try picking a 0.65 to 0.69 to save abit of money as there’s a price jump at 0.7c
xxvvvxx
No idea if that’s a dull rock or a well cut stone
Will this help?
Measurements 5.35 - 5.39 x 3.35 mm
Depth 62.3 %
Table 58 %
Crown Angle 36.0°
Crown Height 15.5%
Pavilion Angle 40.8°
Pavilion Depth 43.0%
Star Length 50%
Lower Half 80%
Girdle Thin to Slightly Thick, Faceted, 4.0%
Culet NonE
Miltah
Will this help?
Depth 62.3 %
Table 58 %
Crown Angle 36.0°
Crown Height 15.5%
Star Length 50%
Lower Half 80%
Culet NonE
Here’s a triple ex dull rock
Your stone is cut deep and it’s got non complementary crown with pav angles
Looks like it’s cut max for weight
xxvvvxx
Seems like all the diamonds given is not worth the price :( but under naked eye.. does it matter? Or what's the factor to look at?
xxvvvxx
Any idea what will be the price range like at HOH for such diamond?
0.5-0.6 carat
Ideal Cut or Excellent Cut
G-H color
SI1
Miltah
0.5-0.6 carat
G-H color
SI1
If u after SI1, u might have to go online
0.58 G VS1 $3,250 (ideal)
0.56 G VVS2 $3,300 (ideal)
0.58 E VS2 $3,500 (ideal)
0.51 G VVS2 - $3,500
0.54 F VS1 - $3,850
0.53 E VS1 - $3,900
0.52 D VS2 - $3,850
0.52 D VVS2 - $4450
0.63 F VS2, $5100
0.71 G VVS2 $5200 (ideal)
0.72 F VS2 $5400 (ideal)
0.60 E, VS1, $5400
0.60 D VS1 $5300
0.62 E VVS2 $5600
0.80 G VS1 $5700 (ideal)
xxvvvxx
0.54 F VS1 - $3,850
0.53 E VS1 - $3,900
0.52 D VS2 - $3,850
0.52 D VVS2 - $4450
0.63 F VS2, $5100
0.60 E, VS1, $5400
0.60 D VS1 $5300
0.62 E VVS2 $5600
Ok thanks for the info!
saltyman
Hi everyone, i am thinking of purchasing a loose diamond online, and making the setting locally in sg,
any good local store to recommend to make setting?
Are these stores good?
https://www.morethandiamonds.com.sg/
https://www.thecanarydiamond.com/heritage/
Are there any concern if i were to buy diamond online and do setting locally? (Diamond chip during setting isit convered by store?)
For setting, 14k White gold vs Platinum
which will be a better choice?
Miltah
Others who bought online have used Canary to set with good feedback.
MoreThanDiamonds is old skool with sketches. Seem to do more resetting of heirloom stones. Husband wife team if I’m not wrong. Crafter is local so u might get it sooner as compared to sending it overseas to HK crafter.
Setting chip. Personally if a store takes your stone n agree to set for u. They should wear the risk if not then just reject the job rather than accept it. But every jeweller is different, best u check.
White gold is plated n can only be polished 2-3 times as it wears the material down. Tends to be more shiny than platinum. Platinum is harder but scratches to get a patina look. Both different,
KinoChoco
If I’m not wrong by default if a jeweller does polishing for your white gold, they have to re-plate rhodium isn’t it? Hence technically u can polish a lot times as it will re-plate it every polish? That’s what I recall knowing, haven’t heard of anyone that polishes white gold and doesn’t re-plate it
Miltah
https://www.jannpaul.com/content/Rhodium-plating-service
“polishing involves the removal of a fine layer of metal. Thus, JANNPAUL recommends not to have this service carried out more than twice in the lifetime of your jewelry”
Yes that is correct. But u always removing more material than u plate.
N u can’t just plate over plate without polishing as rhodium is brittle if it’s a thick layer.
So technically if u send to JP for polishing more than twice. It’s probably time for a new ring.
KinoChoco
Oh hmm, didn’t know they wrote that, most rings are good for 3-4 times, I guess writing recommended 2 times is just to ensure they cover themselves legally if any issues 🤣
Miltah
Yup I’m sure there’s a level of safe tolerance built into that but it wouldn’t be a bad idea to redesign a new ring for a 20yr anniversary perhaps
ThiamWan
Hi guys! Would like to hear some of your advice/opinions, pls. I am currently considering between a;
a) Super ideal cut, 0.8ct - $8300
b) Ideal cut, 0.9ct - $7800 (Estimated)
Both are from JannPaul, prices are for diamond alone
Based on these mere figures alone, which one would y'all go for? Thanks in advance!
Depends on the other grades like the color and clarity bro. Also see what’s the reason of why that Ideal didn’t make the Super Ideal cut. If you want to be safe, go for the Super Ideal.
