Proposal Ring - Part 3
dearmisterj
We have sort of eliminated Octagon, don't really fancy the shape haha
So now considering between super ideal and Solasfera 😄
If that's the case and your SO does not want the 'disco ball effect' (which frankly I am not a fan of either), go for the super ideal :) depending on whether you want to stick to the previous budget of the solesfera, you could probably bump up the carat size of the super ideal and give your SO a little happy surprise ;) either way JP's diamonds are really top grade so whatever you get will most probably be worth the buck
lesnarchen
Thanks for the info bro 👍🏼
xdarrenx
Hi all,
Recently went for a diamond viewing and was offered this
0.45c F vvs2 triple ex , GIA 7211853695 with hca score of 0.7.. saw the ideal and aset scopes, looks fine to me but still my first time looking at the scopes so there might be some off judgments.. any opinions base on the specs?
Approx $2k
MikeLou
Hi all,
Approx $2k
specs seems good.. Though most important is still the scopes.
DiCaprio
Hi all,
Approx $2k
It's probably an ideal and not a super ideal cut right? To my knowledge a super ideal equivalent should set one back about $3+k
Sent from the dark side of the moon using GAGT
MikeLou
Below are the scope images for the 2 diamonds, need the advice from you guys :)
AGS 0.606 E Colour VS1
>>http://imgur.com/CpPnAQs<<
>>http://imgur.com/0YuqLxj<<
>>http://imgur.com/0mQi3ip<<
>>http://imgur.com/5FtA6fa<<
GIA 0.54 E Colour VS1
>>http://imgur.com/UyZl9nA<<
>>http://imgur.com/zM1osod<<
>>http://imgur.com/g28u6Vf<<
>>http://imgur.com/2qqoFCb<<
Thank you
Both are just as good to me.
xdarrenx
Yea u are right, according to the person, its a ideal H&A, so i guess its worth thr price quoted?
DiCaprio
The pricing seems right for an ideal. Do you happen to have the scopes? We don't get a lot of ideal scopes here, it'd definitely help buyers who are deciding if it's worth it to get a super ideal over an ideal.
xtwis7
Comments on this GIA stone from a private jeweller? 2217717829
0.71 G VS2 triple ex
HCA score is 1.3.
Price seems reasonable to me but of course I haven't seen ideal scope images since I don't know if they provide it.
Lydia.Tan
I think Super ideal and Ideal can vary alot. You can compare the difference here. The Ideal cut has a 1.1 HCA score but still cant perform as good as the Super ideal
Lydia.Tan
HCA score is 1.3.
You can try asking JP with the gia number. When I was looking around, I shared the gia number of the diamonds I saw elsewhere. Surprisingly, they had access to some of them too and even quoted a lower price. But after checking, they were not Super ideal cuts which was why they were cheaper.
I settled for a Super ideal cut in the end. It did cost abit more but I thought it was well worth the bling.. It's once in a lifetime anyway and I don't plan to upgrade it in the future :)
TheNormalOne
New jp video, I dont know how I missed this setting when I was there last time... my SO has been looking for something like this all this while
DiCaprio
The Verragio setting is stunning indeed! But the price was a little over the top for me lol. Opted for a customised design based on the Verragio, just collected mine today and I must say, the workmanship by JP's crafters is indeed amazing. If anyone is interested I can share a couple of pictures :o
xtwis7
Yea, I won't be surprised if it's not the equivalent of JP super ideal. For my SO, she really doesn't mind if she can get a bigger carat so just trying to fit everything with my budget.
yukiyeoh25
Can share the pictures? Can't pm due to low post count.
dearmisterj
Just know what you are paying for then as each person's preference is very different. imho i'd rather be paying more for a shinier diamond. my SO likes to compare and I'd rather she has a smaller diamond than a peer, but definitely not a lower quality one ;)
