Proposal Ring - Part 3
josie91
Hi all,
Jannpaul sells solasfera, house of hung inventory also have solasfera. Does the quality differs? Like the cut of the diamond is not as good or something?
midlife
Hi all,
both of them are the same company. iirc house of hung run by papa, JP run by his son.
naxnaxnax
So the quality of the diamond is the same? No differentiation as to whether its from jp or house of hung inventory?
JP has strict quality control, which means that certain diamonds that are rejected by JP is taken up by HOH. It doesn't mean HOH diamonds are bad, it just means those diamonds might not have met JP's quality standards.
For example, JP doesn't stock flat diamonds, e.g. 0.40 carat, 0.50 carat. So those diamonds are taken in under the HOH brand.
midlife
i think they use different staff but sell same things in the same shop
you can try ask them lol
have you went before?
lonestar86
in this vid, a super ideal cut diamond was compared to a triple excellent cut diamond. what would be the price difference if the color, clarity and carat are the same for both ring? sorry if my question doesn't make sense as i am just starting to research on diamond. thks!
coolhead
According to their email correspondence with me, a super ideal cut is 30% approximately more expensive than just a triple excellent ring.
lonestar86
Summary of all their diamond cuts. They really do shine man...
although i am a guy, i gonna say i am falling in love with both the Solasfera and the Octagon cut diamond:s13:
would love to propose to my gf with either of the cuts:)
coolhead
thks for the info! how abt the Solasfera and the Octagon cut?
not really sure as solasfera didn't make much difference to me on a less than 0.75carat ring. I'm sure the more numerous facets will make a difference to a bigger carat ring though.
lonestar86
is it right to say that a diamond is well cut when its HCA score is between 0 and 2?
can a triple excellent diamond's HCA score be between 0 and 2 as well?
ricky48
Does anyone ever asked for discount buying diamond at JannPaul? Did you get it? If yes, how much lower?
dearmisterj
my understanding is that the oct and solesfera is approx 10% more than the super ideal, though each diamond is different and is priced accordingly to the 4Cs, apart from their shape.. just check with JP for diamonds that fit your budget and see which you prefer :)
dearmisterj
the triple excellent score is a broad range of diamonds, and could have HCA scores between 0 - 2 or even higher.. a point to note is that the HCA score only measures the light angles of the diamond, the lower the score, the better proportioned it is to reflect light.. that being said the proportions are only one of the considering factors that makes a diamond bling, for JP if I'm not wrong, the HCA score is only used to filter the better proportioned diamonds for further scrutiny.. to meet the super ideal standards, other factors such as light return, the symmetry of the hearts and arrows etc are also taken into consideration.. as such you can conclude that the super ideal range in JP is definitely a trip ex diamond, but not the other way around.. you can go for their diamond education to get a better understanding of this :)
Sessygurl143
HCA is used as a rejection tool and not a selection tool that means that a high HCA means a bad diamond, low HCA does not means good diamonds. Most importantly still need to analyse the diamond through the various scope esp the Aset scope.
coolhead
Was planning to propose in Japan. Any recommendations from you guys?
Lol... I was planning to propose in Iceland. But I scare she lose her ring.... Omg, the scare is real I tell u. So I change my plan to booking a club/executive room hotel stay one day before to propose to her.
