Proposal Ring - Part 3
Lss
hmmm... i was considering if I should downgrade from E to F and VS1 to VS2 with a price difference of S$900. My friends are telling me that its not worth. :s22:
humm 900 dollars in percentage would be how much cheaper?
Quite common amongst my friends to wear both the engagement ring and wedding band.
What I do is to send my gf ring photos and gauge what her likes/dislikes are, then I can make an educated guess on the ring design and still keep it (relatively) a surprise! :s13:
Lately, I find myself paying attention to girls hands in public and see what ring they wear and if they got where together :s13:
I'm waiting for JP to send me my ring 3d design in 2 weeks. Did you customize your ring?
KinoChoco
Depends, if your diamond is 1 Carat and above, then maybe i'll keep E. but if it's below 1 Carat, 900 (assuming it's 10% of 9k), i might drop to F and use the money for higher carat size or for wedding band. :s13:
Secretyt
It is below 1 carat and I don't intend to up the carat size.
It's about 9.6% lower? Would you think its worth downgrading?
Lss
thats quite alot imo. i would downgrade if it is a solitaire setting. if you have side stones differences in colour might become more apparent, so a better colour would be good. wedding band got any diamonds?
Secretyt
It will be with halo setting and twisted side diamond. Still considering on the wedding band as I have gemstone below the diamond and it may scratch the wedding band.
mero_cwj
IMO, with a halo setting, don't need to be a top grade color and clarity diamond, because visually it will look like a lot of things are going on, and the colour and clarity of the diamond will be rather obscured.
But this is the opinion of a person who hates halo settings, so take with a pinch of salt lah haha.
cherrystalk
I feel that the halo setting overshadows the main diamond. But it's good to have a halo if you wna enhance the overall size of the ring. A bit flashy for daily wear imo.
Lss
I feel it's the reverse. With so many diamonds any colour on the main diamond will get magnified.
etoilebiscuit
did they tell you they will send you the 3d design or more of its automatically will send u?
Secretyt
Hahahaha, thanks for all the opinions! I have always wanted it with a halo because it niceee~
But still, I have to decide whether to get E or F. :s22: . Perhaps I will see both scope before I decide!
cherrystalk
That's great! I'm still v indecisive about the design that I want haha.
KinoChoco
Quite true, i was told by them too that even with a D color diamond, it may look less white as compared to the side diamonds (especially halo being one of the design with the most side diamonds...) due to the small sparkles reflected out by the small diamonds gives the more 'colourless / icy' effect hence the middle stone might not look as white. Partly also because JP uses high grade D-F melees for the sides hahaha.
In this case i'll recommend Secretyt to stick with E and not downgrade to F.
mero_cwj
yeah 6 prong. do you have a picture that i can view?
my SO prefers something simple and classy. haha. even a slightly twisted band at the stone is too complicated for her.
My 3D render is ready! Actually the first draft was out the day before but some of my ideas didn't work so I asked JP to simplify the design.
6 prongs, cathedral setting, the band is a knife edge design with a slight taper.
Secretyt
Thanks for your recommendation! I will re-consider :)
Sessygurl143
Your design looks so classy! Niceee !!!
mero_cwj
One more render of the side profile
A little undecided over whether to go ahead with this design, or go in the other direction with a more blingy, but still very classic design which JP posted recently on their FB page. Would choose white gold/platinum instead of rose gold though.
https://www.facebook.com/JannPaulDiamonds/videos/1230979666934512/
What do you all think?
prudencezee
Its classic and pretty! I went for the same design too (cathedral & 6 prong) but added a little carved out heart :)
fuzygal
Ooh the one with side diamonds is nice. How big is your diamond? I like the clean classic design :)
