Proposal Ring - Part 4
sotongster
Thanks for contributing your view! Yeah, was told by them that the 0.8 carat ones are in the 10k+ range already. I guess this 8.8k is worth it?
you go ask other shops. 0 inclusions vs1 clarity how much for 0.78 natural. sure u -turn and by the stone immediately.
illusioned
Debeers increased diamond prices again last month by 8-20%. That’s on top of a 23% increase since last year. Its a matter of time when this increase will hit the retail.
https://www.mining.com/de-beers-makes-diamond-buyers-cough-up-with-fresh-price-rise/
Closest whiteflash ACA are,
0.93 D VVS1
USD 12,742 = SGD 18,542 with 7% gst
https://www.whiteflash.com/loose-diamonds/round-cut-loose-diamond-4462559.htm
0.92 E VVS1
USD 9,750 = SGD 14,188 with 7% gst
https://www.whiteflash.com/loose-diamonds/round-cut-loose-diamond-4198076.htm
and don’t forget, your comparing it with a white series
Thanks for sharing. Good info. Any take on lab grown diamonds from JP instead? Might wanna consider them since there’s significant cost savings. I know JP is superior in diamond cuts. But not sure if it’s a place to look for lab grown ones.
LifeIsJinHappy
Looking for kind reviewers for the gem I was offered. JP lab grown, but still, wanted to see if any other comments.
1000smiles
Lab grown diamond has their own quality issues too besides the cut. And no one even addresses these issues about labs except JP afaik. Looks like they really wanted to refine their quality before even offering lab growns, that’s a long list of requirement, I didn’t know Jp labs are all type 2a as well.
https://www.jannpaul.com/diamond-price-guide
sotongster
before buying LG , pls be sure your future wife is ok with it first. not everyone is ok with lab grown.
sotongster
Lab growns have to worry about inclusion, striation/ strains etc. Not forgetting the wait time. JP LG is notoriously long wait time.
Miltah
It does take up to 3mths to grow one and that’s not even including the cutting
illusioned
What does type 2a means?
1000smiles
Type 2a is the purest diamond. In natural earth mind diamonds, they make less than 1% of the world’s diamond. Lab growns can be grown to Type 2a too. You’ll only know whether it’s type 2a or not on the certificate. But note that type 2a doesn’t mean it will now have brown or blue hues that’s often associated with lab growns. So those you’ll still need to check.
DeadBoy95
Hi Shifus, anyone can share your opinion on this piece of labgrown?
0.906 carats
Cut Grade AGS Ideal 0
Color Grade LG-AGS 1.0
Clarity Grade LG-AGS 2 (VVS2)
AGS 404051667016
Thanks in advance!
poppyland
Hi all, may I ask if 53.2% is considered a smaller table % for a 1.060cts decagon cut?
Colour Grade: D
Clarity Grade: VVS2 (Clarity Characteristics: Pinpoint)
Thanks!
freewilly5000
Colour Grade: D
Thanks!
The White series doesn't follow the same ideal proportions as the 57 facets round brilliants. More importantly is the light performance that you see from the scope. Also, the table % in relation to the carat weight doesn't matter as its just the % based on the dimensions. You have the cert and scope images? Those might be more useful. Yours is a white series anyway, which is already the top of the top. lol
Sam Sniff
Anyone know how much does wedding bands cost at JP?
Half Eternity 18k Gold ring (double banded) + Plain 18k Gold ring = $2,800
If i had gotten the half eternity ring (single banded), it would have been $2,300
You'll need to check the latest prices, because as you may know, Gold prices have increased, and De Beers just increased their diamond prices (again, as usual).
