lxb_70
- May 3, 2006
I kena… the bolt nut they tiao kang loosen it. The gas slowly leak.Yeah.. don't fall for the gas leak scam.. if it really leak, you should go after the original installer who likely may have caused it.
I got conned once at my previous home. AC was working fine just needed a cleaning service, guy came and claimed gas low. I went ahead with the top-up and within 3 months my AC system stop blowing cold air. Ironically, the top up actually caused the leak in my refrigerant.
i m high usage user. every nite confirm aircon for sleep.
if wanna save inconvenience that cause aircon down due to water leaking... call for aircon servicing every time it cross 6 mth just for FCU in your bedroom...
Karcher WD1 will do, you need to diy simple pvc pipe to fit the aircon hose.Going to give this DIY cleaning a go.
Which model of Karcher vacuum, please?
Something like in this photo
Aircon tech love the top up gas scam. Mine in third year already demand that it needs to top up. I refused now after nine years still cold. These tech are just trying every tactic to squeeze your money.Yeah.. don't fall for the gas leak scam.. if it really leak, you should go after the original installer who likely may have caused it.
Hmm, i think not necessary to buy the more exp model if you buy it just for cleaning the aircon. The 1000w suction is more than enough to suck the jelly and the dust from the aircon fin.Thank you!
Read that the WD 3 is an upgrade option?
yes, better engage long term contract, that does charge by visits. so if they screw up the servicing, they have to fix it. plus if they have physical office that you can visit in person to make noisethose ad u received in your letter box telling you $20, $40, etc. can ignore, throw into trash bin. how they earn? top up lor. kena a few times. once really did top up, few months later, tried another contractor servicing, they said my ac need top up, straight up i know dishonest prick, as I just did few months back. Told him I just do 3 months ago, he diam diam, some more forget to bring this that, after service straight leak water. still can say cos aircon serviced already now is cold, normal to leak water. if u cannot live without ac, invest in a maintenance regime with reputable contractor better.
