Quiet Gaming Rig v2
shadow84
I am not sure if it is available in SG.
I have Windows 7 64-bit on hand.
I see most pricelists dun have that model. Anyway for semi-modular, the 3 cables are gonna be used anyway, so dun really matter if it is modular or not. Unless you are gonna buy sleeved cables which are very ex.
xRenol
Someone recommended that model to me.
I do for full modular PSU due to better cable management that all.
shadow84
Not that true... Modular psu oso gt cables attached frm psu to parts, same as semi modular. Is your skill in tying the cables to your chassis, and not the modular part doing that for u.
Not meant to be rude but if u no skill or bo put in effort in making gd cable management, give u modular oso no point.
I spent like 1-2 hrs in trying to make the back as neat as i can, and without any cables sticking out as much as possible.
xRenol
No worries, I get your point.
xRenol
CPU & Mobo: INTEL i5 4750 + ASROCK H87 PERFORMANCE
Ram: G.SKILL RIPJAWSX 1600 MHZ CL9 2 x 4GB
GPU: MSI GTX 760 2GB HAWK
SSD: PLEXTOR M5 PRO 256GB
HDD: WESTERN DIGITAL 1TB BLUE 64MB
ODD: ASUS 24X DVD-RW SATA
PSU: SEASONIC X SERIES 650W
CASE: CFRACTAL DESIGN R4 TITIANIUM WINDOW
CPU Cooler: COOLER MASTER HYPER 212X
OS: Not required
Based on the above parts, do I need additional fans for gaming PC?
Bump for advices.
MoneyFace =p
Going for GTX 670 means downgrading my GPU.
Nope it's an improvement. GTX 670 has always been one or half a tier above GTX 760.
xRenol
Thanks for the info.
PC Themes is only offering 30 months warranty for MSI GTX 670 2GB Power Edition instead of the normal 3 years.
MoneyFace =p
Yup but you only loses 6 months for substantial savings and better performance. :)
xRenol
Based on MSI website, it seems MSI GTX 760 HAWK (1111MHz) has a higher core than MSI GTX 670 POWER EDITION OC (1019MHz) without overclocking yet.
royfrosty
You cant basically just see base clock and determine which is better.
