Ram and motherboard problem : (
urazix
Hi all, need some advice from the pros here :(
had a problem with my desktop just now in which it keeps retarting but won't boot
googled and found a solution which is to reseat my RAM, did that and found out that the problem (probably) lie with one of the DIMM slots
note: desktop comes with 2 4gb kingtonddr3 RAM cards, tested both. no issue
question now is: should I just replace the 2 4gb with a single 8gb ram, or send my desktop in for repair (which will probably result in replacing my mobo)
ZrE0_Cha0s
do u have another mb to test? and maybe u can do test using memtest +86
urazix
dont have leh. but i swapped the ram around and tried booting with individual cards and found out that the 2 ram cards are okay, jsut this one slot when inserted with a ram card, the desktop doesnt boot : ((((
ZrE0_Cha0s
maybe u can try cleaning the gold contact on ur ram and try and see. clean it with soft eraser.
yusoffb01
One 8GB ram is less than $50 now. Cheaper than u send in for mobo replacement (unless it has distro warranty then free)
nonamesg
Use a soft eraser and rub the gold color contact. This might help if it is not a ram chip fault, just contact issue.
