davidktw
- Apr 15, 2010
Only 15 Pi-s in Singapore?
Raspberry Pi Tracker
Definitely more than that
Too bad no dual network ports. If got, can try using them as routers.
You don't need multiple physical network ports to perform routing![]()
Router on a stick?
The Pi has HDMI output and GPIO. Why limit yourself to a openwrt use case?
Extracted from the Pi forums:
Media centres and gaming
Networking and servers
Graphics, sound and multimedia
Cases
Screens and displays
Other Projects
How does that work? Multi-home?
mine already arrive since 14 June.
What that all you used the Pi for?
mine still in the box, I only just created the OS in SD card, not yet login to it also.
i used mine as:
1. web server
=>installed apache2, php, and mysql, running with 2 virtual host so far (24x7)
=>power consumption is much cheaper than my previous setup(macmini)
2. shell
=>I normally use it as wol client to my other machine (my router, doesn't forward wol package)
Anyway, I've overclocked mine to 855/500 (cpu/ram clock)
i used mine as:
1. web server
2. shell
you set it as media web server?
I think you can set it as cheap router, firewall, proxy and network sharing machine.
I actually got something in my minds ,I want to build UAV with Pi as the core brains for controlling the wing, rudder and throttle of the plane and it also used for processing the image from camera.
the main problem came from the other supporting hardware, because of export regulation and security act, I scrap the idea.
airframe, communication, encryption and media streaming will give me a lot of trouble later on, better be safe than sorry.
I start another project as a home automation and media centre, now start ordering the required part
