Razer Deathadder V4 Pro
obichacha
Only problem with the DV3 Pro is the scroll wheel. It literally is ****. Phantom scrolls when gaming. I sold it off after 2 weeks. RMA will not solve the problem it's an inherent issue with the encoder. Not sure if Razer fixed it in later batches but it's the worst scroll encoder I've used.
DV4 Pro scroll wheel replace to optical wheel.
Should be greater than many mouses, I prefer the optical an over mechanical switches. My keyboard razer huntsman TE till now.
BallGag
Worth to get viper v3 pro or DV3 pro for this time. They are plenty of stocks available right now.
Actually DV3 pro 1000 polling good than enough for me
I bought the hyperpolling dongle for the DAV3 but I rarely change the polling rate on it. Have a Viper V3 Pro too but I prefer the shape of the V2 Pro and even the Ultimate. I've been using the Vaxee Sora and Lamzu Maya X and they are both pretty good. Will probably get the DAV4 during 11.11 sales or something
elmariachi
Maya X is pretty damn solid. Second after that is Darmoshark M3S Max. Both goated shapes I play best on. DAV while good, just seems too big for me to flick and micro-adjust when playing shooters.
obichacha
I like the new polling dongle same design as previous DV2 pro , light battery’s indicated
BallGag
Nice, is that the Aimlabs edition ? I have a plain black one; regret not getting the grey. Do you happen to have the Paro ? Been thinking of getting one, but I already have a DAV3 Hyperspeed and they seem pretty similar
elmariachi
Yes Bro that's the aimlabs one. Paro is a slightly smaller footprint of the Deathadder so you won't be missing out much as far as shape is concerned. I personally do not like these shapes as it restricts the way I flick and micro-adjust due to the high hump in the centre. I've always preferred shapes like Maya or the Darmoshark M3S Max as it gives me alot of flexibility to be agile with the mouse. The M3S Max shape is similar to the Zowie S2 shape which to me, is the best shape for my hands. The Maya X is also good just that the hump is slightly towards the centre but it works for me too as it's not restrictive. DAV shape is either like it or hate it one. Personal taste but it makes me play bad for fast fps shooters.
obichacha
all the shapes design is depending.
I prefer DAV3 hyperspeed mini size or cobra wired, using for more than few hours later , feel a bit tired.
the DAV3 Pro use for whole day 8-11 hours my hand still comfortable.
Viper V3 pro are good too, after replace with glass feet’s, not good use works anymore.
There are too smooth the cursor can moving away if I quick clicking.
but good for gaming only.
If the DA V4 pro no fingerprint marks should be all good.
I will get during 11.11
obichacha
Haha is this DA v3 pro can do better?
If you own the DAV 3 pro more than 2 years maybe can upgrade or just continue using the DAV3 Pro till Viper V4 pro come out then decide again
obichacha
currently do some modified weight on deathadder v3 hyperspeed.
hopefully no outdated, still can fight few more years
obichacha
Just got an the cobra hyperspeed yesterday.
This is the best of the best, around 60g the shaped are mid and smaller size, the optical wheel super smoothest and the gen 4 optical switches are greater and good batteries life.
to me the size and ratio are just right for hand grip.
The cobra hyperspeed bodies coating with texture same as viper v2 pro or deathadder v2 pro, there are no fingerprint marks or my sweaty marks.
Comes with internal profile and Bluetooth.
The overall rating was 10/10, highly recommended
