RE: iPhone 12 Pro | Pro Max freeze
LIN_JOEL
Who else got this issue, it happens on 12P and 12PM.
Under setting, when scroll down to the bottom showing apps.
Click in will hang and auto exiting out of setting and back to home screen.
some of the apps when u open will hang and auto exit.
Apps store couldn't update.
All these need to reboot or reset phone network setting and happens once a while.
***my Lazada apps 1st time showing unexpected shut down and showing click to recovery button....
All solution beside keep rebooting or reset network?
VodkaPear
Encounter similar, but I do a fresh installation.
When I restart the phone all ok already.
VodkaPear
You mean set as new phone and redownload apps one by one thru apps store?
I meant I set up as new phone n re-download all apps 1 by 1.
But also encounter this on my phone and my wife phone (both set as new phone).
So I guess should by iOS 14.2 issue? I don't know, jus guessing.
lkinm81
I download POSB app, but when login it will become Dbs colour scheme.
does it affect too?
For me after iOS 14 update , this 2 apps will hang my phone occasionally and after I removed so far my iPhone is ok now ..
memoriess
try updating to 14.2, previously i had this issues on 14.1 but all gone after updating to 14.2.
Bionic_Chip
I don’t have the issues that you mentioned, maybe try reinstalling the app again and restart the phone before reinstalling?
Matrock5
No wonder I thought how come when I click on my singpass app it froze and I could not go in. I went back to my Home Screen and click again then it was ok. Jia lat. so far haven try for the rest. A few others was ok.
Ahkunkun
I have the same issues from time to time... iPhone XS Max and yesterday my 12 Pro Max 1st day encounter already...
lkinm81
I have the hanging issue since iOS 14 was released on my iPhone 11 and 12 pro .. reinstall the app few times and even done factory reset for 6 times in a month , so far I only encountered DBS app is the main culprit ..
After I removed the app , so far I don’t encountered any hang anymore
cloud77
i did a system restore from previous iphone 11 pro max image (after updating new iphone 12 pro max to 14.2). Some app does not work well or hang, i got to uninstall and reinstall the app again.
sansanjikikut
What makes you think is the Dbs or posb digibank app? I did a quick test and you are right. Login to bank app then log out. The issue will confirm happen, weird. Hopefully Dbs fixes it.
lkinm81
Oh.. After I seek apple support for help which unfortunately they can't find the solution. The last resort that I have done was factory reset my iphone and reinstall and try each app 1 by 1 (which is time consuming)
And that's when I found out the dbs/posb app have the issue with the ios 14. Like you said , after I log in and log out the app , my whole iphone will start to heat up and some of my iphone setting will hang
And now I still waiting dbs to fix this stupid issue
