Real International speed tests
What ISP are you testing on?
  • Total voters
    64
seowbin
need to test CT and CU.
CM i have not mentioned to the monopoly part
lobukong
I heard it's because so many people in china need to bypass GFW that it has already become a business.
If a connection to China (not from China, as most people need to download not upload) is cheap and good, the news will spread and a lot of people will use that connection till not useable anymore. So it's not possible to have a cheap and good connection to China.
I did find my speed test results prove above statement correct as I had more than 900M down but below 1M up.
Henry Ng
Must see which city of China as my speed test to Chengdu is good 900+ DL and 900+ UL Ping 120ms. My VPN location setting is Singapore.
lexisnexus
Actually China Mobile has a relatively good international routing compared to China Telecom for most non-business plans.
China Telecom, however, has been notoriously known as "extremely slow international speed" in China, unless people sign up its premium international traffic plans, which only available in a very few cities (for example, in Shanghai, it offers so called "Shanghai Prestige Network" addon).
This premium international traffic plan is backed by China Telecom Next Generation Carrier Network (many people in China call it "CN2"), which provides much much better international routing and speed.
For example, for my M1 network, without CN2, speed between my Shanghai home to Singapore is only around 50KB/s with 300+ms ping (constantly loss package); With CN2, speed is 60MB/s with around 70+ms ping.
As mentioned before, one of the simple test is to use Ping to test `s.taobao.com` as an indication for latency to China, even though low ping may not translate to good speed.
This is from my RT-AX86U router (Singtel 1Gbs) at 10:30pm Friday 17-March-2023 (just finished the test).
Code:
@RT-AX86U-2D40:/tmp/home/root# ping -c 10 s.taobao.com
PING s.taobao.com (203.119.144.58): 56 data bytes
64 bytes from 203.119.144.58: seq=0 ttl=83 time=161.049 ms
64 bytes from 203.119.144.58: seq=1 ttl=83 time=171.455 ms
64 bytes from 203.119.144.58: seq=2 ttl=83 time=187.149 ms
64 bytes from 203.119.144.58: seq=3 ttl=83 time=177.321 ms
64 bytes from 203.119.144.58: seq=4 ttl=83 time=173.191 ms
64 bytes from 203.119.144.58: seq=5 ttl=83 time=186.037 ms
64 bytes from 203.119.144.58: seq=6 ttl=83 time=188.502 ms
64 bytes from 203.119.144.58: seq=7 ttl=83 time=180.616 ms
64 bytes from 203.119.144.58: seq=8 ttl=83 time=184.841 ms
64 bytes from 203.119.144.58: seq=9 ttl=83 time=178.880 ms
--- s.taobao.com ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 161.049/178.904/188.502 ms
@RT-AX86U-2D40:/tmp/home/root# ping -c 10 59.82.9.84
PING 59.82.9.84 (59.82.9.84): 56 data bytes
64 bytes from 59.82.9.84: seq=0 ttl=83 time=136.503 ms
64 bytes from 59.82.9.84: seq=1 ttl=83 time=161.306 ms
64 bytes from 59.82.9.84: seq=2 ttl=83 time=158.380 ms
64 bytes from 59.82.9.84: seq=3 ttl=83 time=138.881 ms
64 bytes from 59.82.9.84: seq=4 ttl=83 time=153.635 ms
64 bytes from 59.82.9.84: seq=5 ttl=83 time=160.630 ms
64 bytes from 59.82.9.84: seq=6 ttl=83 time=144.072 ms
64 bytes from 59.82.9.84: seq=7 ttl=83 time=164.719 ms
64 bytes from 59.82.9.84: seq=8 ttl=83 time=152.056 ms
64 bytes from 59.82.9.84: seq=9 ttl=83 time=165.398 ms
--- 59.82.9.84 ping statistics ---
round-trip min/avg/max = 136.503/153.558/165.398 ms
froztheart
Code:
I got this though, safe to say that its good?
cyberet
Curious to see if theres any changes
VQ @ 12:24am
Server NameServer IDLatencyJitterPacket LossDownload SpeedUpload Speed
Singtel - Singapore136233.03 ms0.33 ms0.00%945.97 Mbps944.65 Mbps
ViewQwest - Singapore20542.55 ms0.29 ms0.00%771.41 Mbps955.22 Mbps
PT FirstMedia - Singapore75562.43 ms0.15 ms0.00%757.91 Mbps948.99 Mbps
Comcast - Sacramento, CA9436214.17 ms1.04 ms0.00%145.08 Mbps344.6 Mbps
University of Texas, Austin - Austin, TX16089209.4 ms0.39 ms0.00%243.23 Mbps521.16 Mbps
SIMPLYCONNECT - Dar es Salaam13902334.84 ms0.66 ms0.00%160.51 Mbps13.3 Mbps
Celcom Axiata - Kuala Lumpur495637.45 ms1.0 ms0.00%704.63 Mbps934.22 Mbps
Bell Mobility - Vancouver, BC17402202.35 ms0.42 ms0.00%64.56 Mbps342.03 Mbps
Telstra International - Hong Kong4434033.36 ms0.16 ms0.00%335.52 Mbps948.07 Mbps
cyberet
@firesong Removed some servers that are no longer operational and added some replacements
Code:
@echo off
:: Create results subdirectory if it does not exist
if not exist "results\" mkdir results
:: Define the filename variable
set RS=.\results\results-%date:~10,4%%date:~4,2%%date:~7,2%.csv
:: Singtel
speedtest -fcsv -uMbps --output-header -s13623 > %RS%
:: ViewQuest SG
speedtest -fcsv -uMbps -s2054 >> %RS%
:: PT FirstMedia - Singapore
speedtest -fcsv -uMbps -s7556 >> %RS%
:: Comcast - Sacramento, CA
speedtest -fcsv -uMbps -s9436 >> %RS%
:: Frontier - Los Angeles, CA
speedtest -fcsv -uMbps -s14236 >> %RS%
:: University of Texas, Austin - Austin, TX
speedtest -fcsv -uMbps -s16089 >> %RS%
:: GSL Networks - Melbourne, AU
speedtest -fcsv -uMbps -s46114 >> %RS%
:: Verizon - Tokyo, JP
speedtest -fcsv -uMbps -s50467 >> %RS%
:: Vodacom Tanzania Ltd - Dar es Salaam
speedtest -fcsv -uMbps -s3846 >> %RS%
:: Celcom Axiata - Kuala Lumpur
speedtest -fcsv -uMbps -s4956 >> %RS%
:: Astute Internet - Vancouver, BC
speedtest -fcsv -uMbps -s32397 >> %RS%
:: Telstra International - HK
speedtest -fcsv -uMbps -s44340 >> %RS%
:: GuangZhou-5G - Guangzhou, CN
speedtest -fcsv -uMbps -s60794 >> %RS%
:: China Unicom 5G - Shanghai, CN
speedtest -fcsv -uMbps -s24447 >> %RS%
:: China Mobile Group Beijing Co.Ltd - Beijing, CN
speedtest -fcsv -uMbps -s25858 >> %RS%
:: Vodafone UK - London
speedtest -fcsv -uMbps -s24281 >> %RS%
:: Odido - Amsterdam
speedtest -fcsv -uMbps -s52365 >> %RS%
Singtel - Singapore136233.21 ms0.35 ms0.00%943.01 Mbps940.58 Mbps
ViewQwest - Singapore20542.63 ms0.36 ms0.00%768.32 Mbps929.6 Mbps
PT FirstMedia - Singapore75562.46 ms0.27 ms0.00%785.52 Mbps940.18 Mbps
Comcast - Sacramento, CA9436227.65 ms0.23 ms0.00%56.72 Mbps344.64 Mbps
fdcservers.net - Los Angeles, CA9916175.3 ms0.17 msN/A60.24 Mbps485.64 Mbps
University of Texas, Austin - Austin, TX16089209.07 ms0.32 ms0.00%193.77 Mbps274.63 Mbps
GSL Networks - Melbourne46114139.02 ms0.2 ms0.00%830.53 Mbps741.09 Mbps
Verizon - Tokyo5046773.19 ms4.25 ms0.00%50.99 Mbps601.69 Mbps
SIMPLYCONNECT - Dar es Salaam13902337.44 ms0.26 ms0.00%56.8 Mbps14.51 Mbps
Celcom Axiata - Kuala Lumpur495611.55 ms0.15 ms0.00%482.35 Mbps941.49 Mbps
Bell Mobility - Vancouver, BC17402202.25 ms0.33 ms0.00%139.71 Mbps155.53 Mbps
Telstra International - Hong Kong4434033.62 ms1.08 ms0.00%259.22 Mbps946.08 Mbps
GuangZhou-5G - Guangzhou6079450.23 ms7.56 ms0.00%356.75 Mbps938.64 Mbps
China Unicom 5G - Shanghai24447368.8 ms0.38 ms124.48%5.4 Mbps5.39 Mbps
China Mobile Group Beijing Co.Ltd - Beijing2585883.02 ms0.23 msN/A848.96 Mbps664.55 Mbps
Mach3.2
Tested on M1 Fibre 500Mbps.
server nameserver ididle latency (ms)idle jitter (ms)packet loss (%)download (Mbps)upload (Mbps)
Singtel - Singapore
13623​
4.1284​
0.26125​
0​
469.99​
471.25​
2054​
3.5189​
0.1185​
0​
476.93​
471.20​
7556​
3.5631​
0.03675​
0​
455.60​
471.98​
9436​
172.697​
0.09925​
0​
440.16​
279.58​
16089​
214.531​
0.27075​
0​
266.10​
259.86​
46114​
89.7468​
1.792​
0​
456.51​
227.31​
Verizon - Tokyo
50467​
166.589​
7.4265​
0​
453.08​
202.49​
4956​
10.0313​
0.22825​
1.97368​
467.99​
178.85​
44340​
49.4612​
97.474​
0.408163​
336.88​
222.40​
60794​
567.744​
311.652​
7.72532​
225.70​
0.62​
24447​
197.82​
0.51275​
0​
179.97​
75.43​
25858​
261.427​
2.92375​
7.7551​
327.21​
1.31​
Edit: Wrong unit conversion for download/upload, edited to fix.
Some servers failed to run.
- fdcservers.net - Los Angeles, CA
- SIMPLYCONNECT - Dar es Salaam
- Bell Mobility - Vancouver, BC
firesong
Deluxe Member
Probably time to update the list. It's been a while.
Mach3.2
I don't think those servers are really down since cyberet managed to test against those 3 servers that failed for me.
Edit:
Singtel - Singapore
13623​
10.0295​
0.89775​
0​
473.3169​
456.2013​
2054​
3.6705​
0.165​
0​
453.4883​
470.5352​
7556​
3.5267​
0.077​
0​
468.422​
470.6074​
9436​
172.689​
0.223​
0​
431.2039​
216.1619​
16089​
214.431​
0.3135​
0​
238.5176​
243.5544​
46114​
89.1461​
0.094​
0​
481.484​
262.2841​
Verizon - Tokyo
50467​
132.035​
5.37275​
0​
464.3297​
230.2008​
13902​
245.551​
0.8245​
0​
27.97969​
89.40952​
4956​
10.6206​
0.6755​
2.43902​
465.2995​
11.0391​
44340​
35.7922​
0.24625​
0​
452.7364​
308.0626​
24447​
184.041​
0.11125​
0​
2.868984​
11.25518​
25858​
261.411​
8.2535​
13.4146​
346.2003​
0.339536​
Bandwidth in and out of China is still congested on M1.
cyberet
Added london and amsterdam, and replaced the 3 servers that @Mach3.2 having problems with.
Code at https://forums.hardwarezone.com.sg/threads/real-international-speed-tests.6405972/post-150967821
Singtel - Singapore136232.46 ms0.1 ms0.00%943.59 Mbps939.52 Mbps
ViewQwest - Singapore20542.48 ms0.04 ms0.00%773.38 Mbps941.08 Mbps
PT FirstMedia - Singapore75562.25 ms0.17 ms0.00%768.04 Mbps939.56 Mbps
Comcast - Sacramento, CA9436227.05 ms0.21 ms0.00%264.24 Mbps398.48 Mbps
Frontier - Los Angeles, CA14236175.12 ms0.22 ms0.00%366.95 Mbps918.24 Mbps
University of Texas, Austin - Austin, TX16089209.09 ms0.3 ms0.00%316.66 Mbps198.26 Mbps
GSL Networks - Melbourne46114139.45 ms0.32 ms0.00%818.8 Mbps948.93 Mbps
Verizon - Tokyo5046771.83 ms0.61 ms0.00%336.85 Mbps355.06 Mbps
Vodacom Tanzania Ltd - Dar es Salaam3846333.3 ms0.18 ms0.00%65.14 Mbps237.36 Mbps
Celcom Axiata - Kuala Lumpur495611.83 ms0.2 ms0.00%488.33 Mbps948.29 Mbps
Astute Internet - Vancouver, BC32397196.36 ms0.17 ms0.00%91.28 Mbps26.6 Mbps
Telstra International - Hong Kong4434032.87 ms0.98 ms0.00%166.68 Mbps206.14 Mbps
GuangZhou-5G - Guangzhou60794207.46 ms0.48 ms0.00%343.6 Mbps451.66 Mbps
China Unicom 5G - Shanghai24447376.19 ms0.8 ms0.00%4.7 Mbps26.54 Mbps
China Mobile Group Beijing Co.Ltd - Beijing2585882.75 ms0.15 msN/A831.99 Mbps944.1 Mbps
Vodafone UK - London24281157.21 ms0.1 ms0.00%809.8 Mbps926.82 Mbps
Odido - Amsterdam52365205.1 ms0.17 ms0.00%735.23 Mbps396.68 Mbps
Some more test results -- Singtel 5Gbps plan (ZTE F8648ONR --> Hasivo switch --> Intel N100 mini PC with dual SFP+ port
To California
Code:
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 50081
   Speedtest by Ookla
      Server: GSL Networks - Los Angeles, CA (id: 50081)
         ISP: Singtel Fibre
Idle Latency:   176.95 ms   (jitter: 0.12ms, low: 176.85ms, high: 177.08ms)
    Download:  3529.37 Mbps (data used: 4.7 GB)
                287.50 ms   (jitter: 74.16ms, low: 173.40ms, high: 768.66ms)
      Upload:   621.19 Mbps (data used: 1.0 GB)
                260.35 ms   (jitter: 71.24ms, low: 173.61ms, high: 346.69ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d81b380e-4509-4b74-bb98-78b8edd21050
  mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 9436
   Speedtest by Ookla
      Server: Comcast - Sacramento, CA (id: 9436)
         ISP: Singtel Fibre
Idle Latency:   189.46 ms   (jitter: 0.13ms, low: 189.34ms, high: 189.64ms)
    Download:  1763.85 Mbps (data used: 2.5 GB)
                300.81 ms   (jitter: 74.97ms, low: 199.63ms, high: 397.71ms)
      Upload:   470.40 Mbps (data used: 620.4 MB)
                276.32 ms   (jitter: 72.39ms, low: 185.10ms, high: 368.26ms)
 Packet Loss: Not available.
  Result URL: https://www.speedtest.net/result/c/2ad21af0-3fc3-41ff-b01c-da1c9406b57a
