Real International speed tests
What ISP are you testing on?
  • Total voters
    64
Singtel 5Gbps to London.
Seems that Singtel latency to Europe is not good in general. Speed can be pretty decent though.
Bash:
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 24281
   Speedtest by Ookla
      Server: Vodafone UK - London (id: 24281)
         ISP: Singtel Fibre
Idle Latency:   240.75 ms   (jitter: 5.29ms, low: 237.45ms, high: 249.66ms)
    Download:  2588.16 Mbps (data used: 3.4 GB)
                356.36 ms   (jitter: 79.17ms, low: 233.05ms, high: 697.65ms)
      Upload:   188.74 Mbps (data used: 325.2 MB)
                362.30 ms   (jitter: 79.48ms, low: 238.56ms, high: 762.62ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/27b7e333-71fb-47fe-9440-c0de15c9b7fd
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 7437
   Speedtest by Ookla
      Server: Vox Telecom - London (id: 7437)
         ISP: Singtel Fibre
Idle Latency:   224.51 ms   (jitter: 0.07ms, low: 224.41ms, high: 224.56ms)
    Download:     9.04 Mbps (data used: 12.1 MB)
                349.19 ms   (jitter: 78.89ms, low: 232.87ms, high: 465.42ms)
      Upload:    36.37 Mbps (data used: 50.9 MB)
                352.26 ms   (jitter: 78.94ms, low: 234.52ms, high: 497.38ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/8c04a8a8-4c57-4211-a9bc-64c34cd1175c
  mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 6115
   Speedtest by Ookla
      Server: Cybersmart Pty Ltd - London (id: 6115)
         ISP: Singtel Fibre
Idle Latency:   239.36 ms   (jitter: 4.01ms, low: 231.22ms, high: 246.22ms)
    Download:   776.85 Mbps (data used: 1.1 GB)
                357.07 ms   (jitter: 79.02ms, low: 229.16ms, high: 524.92ms)
      Upload:   348.28 Mbps (data used: 442.0 MB)
                356.92 ms   (jitter: 79.17ms, low: 234.68ms, high: 481.68ms)
 Packet Loss: Not available.
  Result URL: https://www.speedtest.net/result/c/c980f11d-56fe-4638-b4e1-0a399bb6c70e
To Amsterdam
Bash:
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 52365
   Speedtest by Ookla
      Server: Odido - Amsterdam (id: 52365)
         ISP: Singtel Fibre
Idle Latency:   315.86 ms   (jitter: 0.32ms, low: 315.62ms, high: 316.05ms)
    Download:    97.51 Mbps (data used: 133.2 MB)
               1001.61 ms   (jitter: 93.69ms, low: 307.94ms, high: 2580.33ms)
      Upload:    91.95 Mbps (data used: 152.9 MB)
                494.76 ms   (jitter: 84.85ms, low: 312.63ms, high: 661.37ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/9a979a25-b55f-4916-96b9-fcdbe53bd6f7
To Berlin.
Bash:
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 17137
   Speedtest by Ookla
      Server: Cronon GmbH - Berlin (id: 17137)
         ISP: Singtel Fibre
Idle Latency:   323.99 ms   (jitter: 0.20ms, low: 323.74ms, high: 324.23ms)
    Download:    97.02 Mbps (data used: 153.1 MB)
                585.79 ms   (jitter: 87.64ms, low: 323.17ms, high: 854.53ms)
      Upload:    92.64 Mbps (data used: 125.9 MB)
                500.08 ms   (jitter: 85.40ms, low: 314.36ms, high: 674.43ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/a862af4b-0d5a-4175-a95c-319b4187b923
Related threads:
1) Latency to different part of the world
https://forums.hardwarezone.com.sg/threads/fastest-isp.6996674/page-3#post-151182381
2) China specific
https://forums.hardwarezone.com.sg/threads/china-content-lover-lip-lai.7044620/
This is a more comprehensive test using OOkla SpeeedTest
https://github.com/su-haris/simple-network-speedtest
https://nws.sh/
You may want to modify the script if you are not happy about data collection.
Sample results from my Singtel 5Gbps internet connection, using Intel N100 mini PC running Ubuntu 24.04 (10G capable with dual SFP+ ports based on Intel 82599ES chipset).
A lot of data will be used for the test. Do not carry out the test using mobile data connection.
Total DL Data : 121.29 GB
Total UL Data : 39.45 GB
Total Data : 160.74 GB
Bash:
---------------------------------- nws.sh ---------------------------------
      A simple script to bench network performance using speedtest-cli
 Version            : v2024.09.11
 Global Speedtest   : wget -qO- nws.sh | bash
 Region Speedtest   : wget -qO- nws.sh | bash -s -- -r <region>
 Basic System Info
 CPU Model          : Intel(R) N100
 CPU Cores          : 4 @ 1500.860 MHz
 CPU Cache          : 6144 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ✔ Enabled
 Total Disk         : 233.7 GB (36.8 GB Used)
 Total RAM          : 7.5 GB (1.1 GB Used)
 Total Swap         : 4.0 GB (0 Used)
 System uptime      : 0 days, 19 hour 5 min
 Load average       : 0.19, 0.20, 0.18
 OS                 : Ubuntu 24.04.1 LTS
 Arch               : x86_64 (64 Bit)
 Kernel             : 6.8.0-44-generic
 Virtualization     : NONE
 TCP Control        : cubic
 Basic Network Info
 Primary Network    : IPv6
 IPv6 Access        : ✔ Online
 IPv4 Access        : ✔ Online
 ISP                : Singapore Telecommunications Ltd, Magix Services
 ASN                : AS9506 Singtel Fibre Broadband
 Host               : Singapore Telecommunications Ltd, Magix Services
 Location (IPv4)    : Jurong West, Singapore, SG
 Speedtest.net (Region: GLOBAL)
 Location         Latency     Loss    DL Speed       UP Speed       Server
 ISP: Singtel Fibre
 Nearest          1.77 ms     0.0%    5656.91 Mbps   4983.95 Mbps   Singtel - Singapore
 Kochi, IN        86.88 ms    0.0%    2580.30 Mbps   1072.97 Mbps   Asianet Broadband - Cochin
 Bangalore, IN    FAILED
 Chennai, IN      71.04 ms    N/A     2976.66 Mbps   860.03 Mbps    Jio - Chennai
 Mumbai, IN       75.48 ms    0.0%    2536.62 Mbps   1398.65 Mbps   i3D.net - Mumbai
 Delhi, IN        69.32 ms    0.0%    2574.20 Mbps   1269.84 Mbps   Tata Play Fiber - New Delhi
 Seattle, US      202.49 ms   N/A     1740.28 Mbps   446.07 Mbps    Comcast - Seattle, WA
 Los Angeles, US  175.76 ms   0.0%    1919.60 Mbps   523.83 Mbps    ReliableSite Hosting - Los Angeles, CA
 Dallas, US       198.11 ms   0.0%    1928.49 Mbps   444.47 Mbps    i3D.net - Dallas, TX
 Miami, US        229.73 ms   N/A     2151.08 Mbps   323.88 Mbps    Dish Wireless - Miami, FL
 New York, US     234.13 ms   0.0%    3122.42 Mbps   466.55 Mbps    GSL Networks - New York, NY
 Toronto, CA      233.43 ms   0.0%    1554.80 Mbps   367.03 Mbps    Rogers - Toronto, ON
 Mexico City, MX  200.72 ms   N/A     1513.79 Mbps   400.43 Mbps    INFINITUM - Mexico City
 London, UK       288.43 ms   0.0%    3240.26 Mbps   345.37 Mbps    VeloxServ Communications - London
 Amsterdam, NL    162.62 ms   0.0%    4675.36 Mbps   660.16 Mbps    31173 Services AB - Amsterdam
 Paris, FR        FAILED
 Frankfurt, DE    236.26 ms   0.0%    1588.56 Mbps   369.92 Mbps    Clouvider Ltd - Frankfurt am Main
 Warsaw, PL       319.97 ms   0.0%    3026.89 Mbps   329.23 Mbps    Play - Warszawa
 Bucharest, RO    269.97 ms   0.0%    2213.47 Mbps   342.54 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
 Moscow, RU       285.40 ms   0.0%    3357.03 Mbps   383.28 Mbps    RETN - Moscow
 Jeddah, SA       303.24 ms   0.0%    3457.27 Mbps   361.96 Mbps    Saudi Telecom Company
 Dubai, AE        247.69 ms   0.0%    4045.99 Mbps   394.03 Mbps    du - Dubai
 Fujairah, AE     77.61 ms    0.0%    4594.19 Mbps   1355.48 Mbps   e& UAE - Fujairah
 Istanbul, TR     285.07 ms   0.4%    1988.42 Mbps   134.37 Mbps    Turkcell - Istanbul
 Tehran, IR       226.94 ms   0.0%    2588.87 Mbps   406.64 Mbps    Asiatech - Tehran
 Tokyo, JP        185.13 ms   0.0%    4337.14 Mbps   482.23 Mbps    IPA CyberLab 400G - Tokyo
 Shanghai, CU-CN  62.38 ms    0.0%    4235.28 Mbps   1430.57 Mbps   China Unicom 5G - Shanghai
 Nanjing, CT-CN   331.86 ms           658.38 Mbps    FAILED         China Telecom JiangSu 5G - Nanjing
 Hong Kong, CN    39.45 ms    N/A     3619.69 Mbps   2165.72 Mbps   STC - Hong Kong
 Singapore, SG    3.85 ms     0.0%    5467.42 Mbps   4872.02 Mbps   i3D.net - Singapore
 Jakarta, ID      14.13 ms    0.0%    5174.10 Mbps   4737.70 Mbps   PT Solnet Indonesia - Jakarta
 Avg DL Speed       : 3052.54 Mbps
 Avg UL Speed       : 1080.30 Mbps
 Duration           : 15 min 43 sec
 System Time        : 15/09/2024 - 09:06:54 +08
 Total Script Runs  : 80938
 Result             : https://result.nws.sh/r/1726361876_XEYD24_GLOBAL.txt
https://nws.sh/
Updated result for Europe Only, Singtel 5Gbps Fibre Internet, Linux LxC container on the same Intel N100 mini PC as above. But now the Intel N100 mini PC is running Proxmox PVE 8.3.3. Main router is virutal OpenWRT router running on the same mini PC).
You can see that the speed can be pretty fast but the latency is not so good in general.
Bash:
root@debianct21r1:~# wget -qO- nws.sh | bash -s -- -r eu
 Version            : v2025.03.18
 Basic System Info
 CPU Cores          : 2 @ 3099.906 MHz
 CPU Cache          : 6144 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 7.8 GB (732.2 MB Used)
 Total RAM          : 2.0 GB (33.1 MB Used)
 Total Swap         : 512.0 MB (20.0 KB Used)
 System uptime      : 29 days, 10 hour 53 min
 Load average       : 0.14, 0.22, 0.21
 OS                 : Debian GNU/Linux 12
 Kernel             : 6.8.12-5-pve
 Virtualization     : LXC
 TCP Control        : cubic
 Basic Network Info
 Speedtest.net (Region: EUROPE)
 ISP: Singtel Fibre
 Nearest          1.65 ms     0.0%    5574.93 Mbps   4938.14 Mbps   CTCSCI TECH LTD - Singapore
 London, UK       202.71 ms   0.0%    1559.20 Mbps   55.26 Mbps     RETN - London
 Manchester, UK   274.84 ms   N/A     103.54 Mbps    247.51 Mbps    Vodafone UK - Manchester
 Dublin, IE       236.68 ms   0.0%    2002.83 Mbps   342.35 Mbps    Three Ireland - Dublin
 Amsterdam, NL    257.56 ms   0.0%    3009.72 Mbps   343.57 Mbps    Melbicom - Amsterdam
 Paris, FR        255.93 ms   0.0%    4493.40 Mbps   372.17 Mbps    Scaleway - Paris
 Marseille, FR    281.05 ms   N/A     4004.48 Mbps   334.47 Mbps    ORANGE FRANCE - Marseille
 Madrid, ES       268.43 ms   0.0%    3918.64 Mbps   334.53 Mbps    Orange - Madrid
 Barcelona, ES    228.98 ms   0.0%    789.74 Mbps    377.93 Mbps    Adamo - Barcelona
 Lisbon, PT       259.69 ms   0.0%    1971.26 Mbps   329.05 Mbps    Edgoo Networks - Lisbon
 Rome, IT         302.66 ms   0.0%    2684.29 Mbps   245.57 Mbps    TIM SpA - Rome
 Milan, IT        251.77 ms   0.0%    3029.83 Mbps   182.02 Mbps    Fastweb SpA - Milan
 Zurich, CH       267.15 ms   0.0%    608.27 Mbps    389.60 Mbps    Sunrise Communication AG - Zurich
 Frankfurt, DE    169.43 ms   0.0%    3273.17 Mbps   244.60 Mbps    31173 Services AB - Frankfurt
 Berlin, DE       FAILED
 Vienna, AT       203.58 ms   0.0%    804.27 Mbps    442.68 Mbps    DataPacket - Vienna
 Budapest, HU     308.40 ms   0.3%    23.90 Mbps     227.44 Mbps    ATW Internet Kft. - Budapest
 Krakow, PL       300.80 ms   0.0%    2543.80 Mbps   218.27 Mbps    T-Mobile Polska S.A. - Kraków
 Warsaw, PL       293.55 ms   0.0%    1873.40 Mbps   339.00 Mbps    Orange Polska S.A. - Warsaw
 Lviv, UA         280.06 ms   0.0%    2235.56 Mbps   351.78 Mbps    Kyivstar - Lviv
 Kyiv, UA         265.29 ms   0.0%    1029.68 Mbps   343.51 Mbps    O3 - Kyiv
 Bucharest, RO    285.88 ms   0.0%    2376.32 Mbps   253.67 Mbps    Orange Romania SA - Bucuresti
 Timisoara, RO    283.42 ms   0.0%    2251.24 Mbps   307.99 Mbps    Digi
 Helsinki, FI     282.89 ms   0.0%    2242.46 Mbps   368.50 Mbps    Elisa Oyj - Helsinki
 Stockholm, SE    275.03 ms   0.0%    1878.44 Mbps   201.71 Mbps    Bahnhof AB - Stockholm
 Oslo, NO         291.88 ms   0.0%    2982.57 Mbps   289.57 Mbps    Telia Norge AS - Oslo
 Moscow, RU       293.00 ms   0.0%    3416.70 Mbps   357.60 Mbps    MTS - Moscow
 Petersburg, RU   199.84 ms   0.0%    2586.87 Mbps   477.95 Mbps    t2 Russia - Saint Petersburg
 Istanbul, TR     283.33 ms   0.0%    2379.14 Mbps   291.41 Mbps    Turkcell - Istanbul
 Avg DL Speed       : 2344.56 Mbps
 Avg UL Speed       : 471.71 Mbps
 Total DL Data      : 81.16 GB
 Total UL Data      : 13.81 GB
 Total Data         : 94.97 GB
 Duration           : 15 min 55 sec
 System Time        : 20/04/2025 - 20:57:58 +08
 Total Script Runs  : 108803
 Result             : https://result.nws.sh/r/1745153642_58M40T_EU.txt
New test results from my main OpenWRT router -- now got more failed tests.
Singtel 5Gbps Fibre Internet, virtual OpenWRT router (Proxmox VE, Intel N100 CPU, two virtual CPU core).
IPv4 address -- 119.74.xxx.xxx
Bash:
root@openwrt18:~/ookla#  wget -qO- nws.sh | bash -s -- -r eu
 Version            : v2025.11.07
 Ping & Routing     : wget -qO- nws.sh | bash -s -- -rt <region>
 Basic System Info
 CPU Model          : QEMU Virtual CPU version 2.5+
 CPU Cores          : 2 @ 806.400 MHz
 CPU Cache          : 16384 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ❌ Disabled
 Total Disk         : 3.9 GB (423.0 MB Used)
 Total RAM          : 3.8 GB (141.0 MB Used)
 System uptime      : 6 days, 18 hour 45 min
 Load average       : 0.04, 0.01, 0.00
 OS                 : OpenWrt 24.10.2
 Kernel             : 6.6.93
 Virtualization     :
 TCP Control        : cubic
 Basic Network Info
 ISP: Singtel, Singtel Broadband
 Nearest          1.46 ms     0.0%    5292.68 Mbps   4938.66 Mbps   Singtel - Singapore
 London, UK       232.48 ms   0.0%    4147.05 Mbps   425.25 Mbps    RETN - London
 Manchester, UK   239.45 ms   N/A     272.96 Mbps    355.24 Mbps    Vodafone UK - Manchester
 Dublin, IE       174.59 ms   8.3%    3836.77 Mbps   83.86 Mbps     Three Ireland - Dublin
 Amsterdam, NL    323.07 ms   0.0%    2095.69 Mbps   304.50 Mbps    Melbicom - Amsterdam
 Paris, FR        324.94 ms   0.0%    2312.63 Mbps   296.23 Mbps    Scaleway - Paris
 Marseille, FR    354.76 ms   N/A     2528.20 Mbps   271.13 Mbps    ORANGE FRANCE - Marseille
 Madrid, ES       345.48 ms   0.0%    2107.95 Mbps   270.61 Mbps    Orange - Madrid
 Barcelona, ES    248.74 ms   0.0%    1850.64 Mbps   373.39 Mbps    Adamo - Barcelona
 Lisbon, PT       340.18 ms   0.0%    1803.89 Mbps   282.56 Mbps    Edgoo Networks - Lisbon
 Rome, IT         285.53 ms   0.0%    3478.08 Mbps   362.65 Mbps    TIM SpA - Rome
 Milan, IT        153.84 ms   0.0%    3372.41 Mbps   621.59 Mbps    Fastweb SpA - Milan
 Zurich, CH       164.99 ms   0.0%    1851.03 Mbps   550.03 Mbps    Sunrise Communication AG - Zurich
 Frankfurt, DE    FAILED
 Berlin, DE       342.61 ms   N/A     1685.66 Mbps   76.22 Mbps     Misaka Network, Inc. - Berlin
 Vienna, AT       FAILED
 Budapest, HU     343.16 ms   0.0%    5.76 Mbps      300.02 Mbps    ATW Internet Kft. - Budapest
 Krakow, PL       277.31 ms   0.0%    503.41 Mbps    298.28 Mbps    T-Mobile Polska S.A. - Kraków
 Warsaw, PL       335.39 ms   0.0%    1703.23 Mbps   257.03 Mbps    Orange Polska S.A. - Warsaw
 Lviv, UA         347.66 ms   0.0%    1863.19 Mbps   272.65 Mbps    Kyivstar - Lviv
 Kyiv, UA         184.48 ms   0.0%    2052.79 Mbps   492.96 Mbps    O3 - Kyiv
 Bucharest, RO    356.56 ms   0.0%    1771.88 Mbps   264.61 Mbps    Orange Romania SA - Bucuresti
 Timisoara, RO    339.57 ms   0.0%    775.21 Mbps    234.30 Mbps    Digi
 Helsinki, FI     330.48 ms   0.0%    2826.58 Mbps   247.29 Mbps    Elisa Oyj - Helsinki
 Stockholm, SE    330.64 ms   0.0%    1930.69 Mbps   257.09 Mbps    Bahnhof AB - Stockholm
 Oslo, NO         322.94 ms   0.0%    2433.05 Mbps   294.05 Mbps    Telia Norge AS - Oslo
 Moscow, RU       FAILED
 Petersburg, RU   FAILED
 Istanbul, TR     370.66 ms   0.0%    1464.57 Mbps   211.26 Mbps    Turkcell - Istanbul
 Avg DL Speed       : 2158.65 Mbps
 Avg UL Speed       : 493.66 Mbps
 Total DL Data      : 68.59 GB
 Total UL Data      : 13.26 GB
 Total Data         : 81.85 GB
 Duration           : 14 min 27 sec
 System Time        : 18/01/2026 - 07:51:44 +08
 Total Script Runs  : 516493
 Result             : https://result.nws.sh/r/1768693905_FDLNB4_EU.txt
