[Recommend] fan replacement for hyper 212
shadow84
Didn't know doraemon selling gentle typhoon too, haha. Just checked his carousell, the status is "sold" at the moment :(
Can always PM him for latest info... That would be the best way IMO.
AS1
If you still have the receipt, there should be a one year warranty for the cooler master fan. Otherwise, see what you want to do as high cfm yet quiet will need to spend a bit.
xtractor
oh.. mine is the 212x.. looks a little different don't know if it's the same thing..
btw the gentle typhoon 1850 you guys talk about is better?
same fan im using it last time mine hyper 212x too
haodede
Suspended
If your fan is spinning at 100% (comparing gentle typhoon and 212x), it's definitely quieter by quite a lot.
Why nobody recommend Noctua fan?
Encrypted11
If your fan are spinning at 100% (comparing gentle typhoon and 212x), it's definitely quieter by quite a lot.
As someone who used NF-F12, I can confidently say as RPM ramps up GT goes much easier on your ears than Noctua. The whine at 1500RPM is still ok. Using unscientific tests like placing hand in front of fans, the amount of air pushed on GT are noticeably better on GT.
But in Noctuas may scale with lower RPM. But you get the idea, roughly the type of sound pitch they produce on higher RPM.
Phen8210
alright, i really got to change the fan alr.. problem getting worse noise getting louder.
The stock fan or the GT provide better cooling? i gonna order it today.
