Recommend water heater
Foetid
Mine is also 40L digital heater but servicing cost me $130 including GST although it was nearly 1.5 years ago.
You double check with them the breakdown of $171 and if this amount is also inclusive of 9% GST too.
why servicing? spoilt?
jtsh55
Thanks for the suggestion, I believe the $171 is inclusive of 9% GST. Guess like everything else nowadays, they increase the price to $171 :LOL:
I think so too but it's good to double check with them just to ensure.
Not spolit, it's a general servicing just like AC servicing since we are using the storage heater on daily basis.
LoneTraveller
Heard it was launch in Q4 2024. So trying to see if anyone here has already install it. =)
Maybe u can search online for the specs of kdk water heater and Panasonic water heater. I would not be surprised if they are virtually the same.
dqwong
🔥 Ultimate Singapore Storage Water Heater Guide (EDMW Style)
🏆 Best Brands Ranked by Track Record (Based on SG Forums, Reddit, Reviews)
BrandReliabilityReal Talk Verdict
Rinnai★★★★★💪 Tank legend. Runs 10+ years, zero issues.
AOSmith★★★★☆🔋 Premium build. Efficient but pricier.
Joven★★★☆☆👍 Budget-friendly and okay for 4–6 years.
Ariston★★☆☆☆⚠️ Pretty but leaks fast. Forum horror stories.
707 / Champs★★☆☆☆🤷‍♂️ Mid-tier. Works, but not standout.
✅ Top pick: Rinnai — trusted by landlords, homeowners, and contractors for good reason.
🧾 Real User Feedback (Singapore Forums / Reddit)
  • Rinnai:
    “Used for 25 years, ZERO maintenance. Just works.”
    “ID tried to upsell others. I insisted on Rinnai. Worth it.”
  • Ariston:
    “Started leaking in 2 years. Replaced under warranty, but leaked again.”
    “Nice design, lousy internals.”
  • Joven:
    “Decent for the price. Lasted 5 years, then small leak.”
  • AOSmith:
    “Super consistent heat. Worth the money. Feels like a premium brand.”
💰 Cost Breakdown (2024–2025 Estimates)
BrandSize RangeUnit Price (SGD)Install (SGD)Est. Total Cost
Rinnai15L–30L$280 – $420$120 – $180$400 – $600
AOSmith30L–50L$350 – $600+$130 – $180$480 – $780
Joven25L–35L$230 – $370$100 – $150$330 – $520
Ariston15L–30L$180 – $400$100 – $160$300 – $560
707 / Champs15L–30L$220 – $350$100 – $150$320 – $500
⚙️ Extra charges may apply for:
  • Old heater removal
  • Additional piping/brackets
  • No existing 15A electrical point
🔍 What to Look Out For
✅ Must-have features:
  • Safety ELCB (earth leakage circuit breaker)
  • Overheat protection / auto cut-off
  • SS IEC 60335 compliance
⚠️ Red flags:
  • Weak tank warranties (<3 years)
  • Plastic fittings / thin internal wiring
  • Pushy IDs recommending Ariston “because Italian”
🧠 Summary Cheat Sheet
Want…Get This Brand
💪 Long-lasting, reliableRinnai
🔋 Energy efficient, quietAOSmith
💰 Budget but decent lifespanJoven
🎨 Sleek but risky durabilityAriston
🤷‍♂️ Just need something basic707 / Champs
🛠️ Pro Tips
  • Get your installation done by certified electricians/plumbers — don’t rely on cheap deals if they void your warranty.
  • For BTO or resale reno, ask your ID for Rinnai first — if they say “out of stock,” push back. Many IDs have margin deals with Ariston.
euro2012
why edmwers like scared of instant ah??
i use since baby all the while no problem..
byfun
Everhot and Rheem are both same company. This 2 best value n durable storage heater. Those Ariston and Joven lousy wont last.
RSKeisuke
i think most living in post-2010 HDB with concealed hot/cold piping, so using storage heater more appropriate
