U wan surround or stereo ?
For headset I recommend getting something that
Can cover over ur ear
Not odd shape looking cushion pad
Cushion pad is not fabric or cotton - no idea wad material is dust magnet
Cushion pad can be easily found and replace. Cheap alt as original v costly
Audio not limit to usb output
Over ears can be uncomfortable for those wearing glasses and make your ears sweaty since it insulates the ears.
JVC HA-FX850
Gaming headset is the past now![]()
A50 is like $500 or there and it's difficult to find one with Local warranty..
it's one of the most expensive headset in the market.
Did you even check out the HyperX Cloud II? It's available in your preferred color of Black/Red.
Also, Sennheiser headset doesn't look sleek imo. Perhaps you might want to post an image of the 'sleek' headset you're referring to.
I own the A40 with mix amp. The headset ear cups are cracking and I can't find replacement ones locally. Also, the mix amp rubberised matt finishing is all sticky and gluey due to the humidity. For that price, the quality is only meh. I'm now using other headset till I get the replacement cups from the U.S.
I bought my cloud 2. 109 only
Good price! Share lobang?
SIC please!!
i read around and Astro is supposed to produce one of the best headset for gaming and this is reflected by the pricing.. For me it's beyond what i am comfortable as i find it priced a bit too high and the no-local warranty is worrying for me
Local selling how much?
http://img.creative.com/comex/comex2015.pdf
BlasterX H5 with E5 isnt that bad.
You can email to them to enquire if they stil have promotion. I guess they still have it.
199 + 99 for a good amp
