koroshiya8
- Feb 12, 2005
i'll be using it as a part-time PC-Console kind of treatment and will be sitting pretty far away as per normal television viewing.Waaaah u use 42" tv to play games ?? ****************** ive tried using 32" tv to play games i almost vomit coz headache..so its better to get a monitor with ips panel
CPU+MB: Intel Core i3-4150 + ASUS H81I-PLUS @ $237
RAM: Crucial DDR3-1600 CL11 8GB @ $59
GPU: Sapphire R7-260X 2GB @ $115* (Lazada Singapore)
SSD: Samsung SSD 850 EVO 250GB @ $162
PSU: Seasonic S12G 450W [80 Plus Gold] @ $85
CASE: Jonsbo V3+ [Black] @ $79
Mere 10.1 litres, or 5x Mac Mini stacked up.
OS: Microsoft Windows 8.1 Pro 64-bit Product Key [OEM] @ $33 (G2A)
Total: $770
Buy others from Tradepac, #05-18. Haggle for discounts!
*Price after Lazada App MasterCard Monday 15% discount [Capped at $30]
http://forums.vr-zone.com/hardware-depot/2738831-mini-review-jonsbo-v3-itx-case.html
http://www.techspot.com/review/783-geforce-gtx-750-ti-vs-radeon-r7-265/page5.html
Plus USD too high.....![]()
Thanks Sir.. even got hyperlink somemore ! BTW ya USD is very pain now.. i think 1.4 and above liao
Hi threadstarter, SG13 is good if since it can fit most standard-size stuff and a decent graphics card, but take note:
The maximum PSU depth according to Silverstone is 15cm, but it is really tight during assembly plus need to make sure the cables won't get blocked. And if you use a 3.5" HDD, try to find the thinner 1TB HDD if possible, the 'full-height' ones can block the 15cm depth PSU. Or you can get a 14cm depth PSU instead.
Modular PSU highly recommended because there is not much space within the case for cables, here is an Antec Truepower New which is semi-modular but lots of leftover cable length.
According to specs this casing can fit pretty long graphics cards. But that's just the theory. Installation gets more difficult with bigger cards. This is how it fits a HD7850 PCS+.
It looks like it has a lot of free space left, but is actually quite challenging because of all the cables blocking. Notice the 3.5" HDD cables sharing the same area as the PCI-E power. A longer graphics card will compete with the 3.5" HDD cables.
If you want longer cards, you will have to connect the power cables before moving the card into the chassis, but that also has issues because it is already difficult to move the card into the chassis if the heatsink is big. The heatpipes on the HD7850 PCS+ can block the way for example. So choose a card that isn't too tall.
Thanks.. i also worried about cabling but for 520w i think hard to find modular unless pay more? For GPU i think 750ti is really good and compact plus no need additional power... looks like a neat solution
This review has a rather large GPU and just about fit..
