Recommendation for Mini-ITX setup
Ark Law
If you can wait, you might want to consider this 10 litres sleek console killer: :D
Lack of dust filters was an instant killer for me. Silverstone does a good job of including 2x fans and all dust filters for their RVZ01/FTZ01 chassis. Worth the extra 4 litres in size vs the Node 202
MoneyFace =p
What would be the most value for money SSD of 512GB ? Transcend ?
Yeah but should wait for discount code first. Back last month Samsung giving away free vacuum cleaner for their 500GB SSD, some Qoo10 sellers even add on with extra $30 NTUC vouchers and microSD card. :s13:
Ark Law
Samsung vacuum cleaner like sai one, unless you enjoy having adding an airport to your cleaning chores
koroshiya8
Hi all, reality just set in yesterday LOL.
i was trying to mount a 3.5 HDD but found it's out of space.. end up i give up and decide to get another SSD (going to).... In order to save space i'm currently mounting my SSD on the side wall of my PSU (using 3m double side tape) vertically.. will there be any issues in terms of the lifespan of the SSD ? i dun think heat is an issue right..
kandinsky
Don't think will be a problem. Did your SSD come with any bracket? Maybe can put the tape on the bracket instead and mount the SSD to the bracket. Neater + Easier to remove the SSD say if need to replace/upgrade.
pokey2014
Hi, hijack thread also.. got cosair 380t case, looking for a motherboard either i5 or i7, gpu I have a gtx970 armour from msi on my old rig.
Any recommendation for m-itx board might need to overclock as I play fsx very often
Sent from my ass using GAGT
