Recommendation to Rig
tmfwy
Thank you so much but if I was to stick to GTX1050 will I be able to run DotA at the ultra setting because I doubt I will be playing other games. I really appreciate for you to solve my PSU question at least I know what should I go for now instead
I wanted to with the Krait Gaming because I really like the cool LED but then budget wise is really chor on the pocket though
I considered Ryzen before but after researching for a bit between the two comparison I still decide to stick to Intel
Yep. 1050 is more than sufficient for Dota 2 / light gaming
If that is what your budget permits, it will be fine
For Dota Ultra settings, you should be able to exceed 60 fps minimum regardless of whether you choose an i5-7400 / i3-8100 / Ryzen configuration. You can use these for comparison to find a sweetspot.
https://www.cpubenchmark.net/high_end_cpus.html
https://www.videocardbenchmark.net/directCompute.html
tmfwy
Nowadays suka suka can close thread huh. your summary is the final verdict that should be accepted?
Saw that thread, moneyface already indicated if not upgrading it is still cheaper to buy coffee i3 vs kaby i5 so why your final post mentioned he is assuming everybody will upgrade?
Precisely we are aware not all are tech savvy that's why we are telling them to buy coffee i3 over kaby i5. Wrong for us to do that? And what's the post of preowned kaby system for? Lala recommended or rather approved/agreed TS choice of a kaby i5 new system thus the bashing. If he had said to go for cheap preowned kaby lake system then I'm sure moneyface also won't bashed him.
Forum not for discussion/debate and at same time absorb more info then is for what? Everyone just anyhow shoot recommendations and no one is supposed to disagree is what you want/expect?
Discussions between which is better Kaby Lake or Coffe Lake have proven to degenerate into heated debates.
This forum is meant for discussions in a productive manner. It is no fun if someone has to wade through a ton of brickbats just to find the info one needs for a good rig.
Again, this is a warning not to start the Coffee Lake vs Kaby Lake debate. Kaby or Coffee both have their pros and cons when considering the bigger picture.
AnonymousJon
I believe there isn't any debate so far in the tread as they provided me with suggestion on the CPU followed by the stats.
What about the following built? Is there any recommendation I should consider or any changes that have to be made ? Ideally I will stick to 1050 because the rest seems to cost more :(
CPU + MB : I3-8100 + Gigabyte Z370N WIFI
Memory : 2x4GB DDR4-2400 (Please let me know if ram brand matters)
GPU : MSI GeForce GTX 1050
Case : Cooler Master Master box Lite 3.1
PSU : Cooler Master MWE 450W
^Don't plan to install any additional fan since the case already has one, or should I get one more?
P/S if there's any mATX RGB casing do let me know
Chill, he is just doing his job.
Hailgod
This build should be good enough for now. But if u are a chrome user with 20 tabs or more, you should look into upgrading to 16gb in the future. if thats the end goal, you can go 1x 8gb first for now, even if u get slightly lower fps. I can still get avg of 90 fps on max settings with a 1050ti and single 8gb ram. a 1050 should be around ~20% lower, 75fps avg is still above the 60hz of most monitors.
AnonymousJon
My chrome usually is running probably 1-2 occasionally more but lesser than 7 tabs for sure, plus a WhatsApp maybe.
Guess I would then settle down with this current built ! Really thankful for your help and suggestion :s12: do you think I should get another 1-2 fan since the Lite 3.1 only comes with one at the rear?
Side Question : If I reuse my HDD i would still have to purchase Windows 10 right? or is it usually packaged together when you build everything at one store?
MoneyFace =p
Dont settle just yet. 12.12 is coming in 8 days time. Local online shopping sites will have major promo going on. Do leverage that to save money or boost your specs. So if you can afford to wait, please wait.
AnonymousJon
Oh my, thank you so much for the tip ! Really appreciate the thought of saving my wallet :s12: Definitely going to wait for the sales @ 12.12, or will there be another one at Christmas? (*Fingercross* Hopefully the Alienware last till then)
Which sales will be better to grab the stuff and which Local online shopping should I keep my ones on apart from Lazada?
MoneyFace =p
Lazada, Qoo10 and Shopee... :s12:
Elijahonli
if you still have ur windows 8/8.1/10 key, u can try reactivating... if not you have to purchase a new windows key
Hailgod
if u dun mind the watermark u can just install windows 10 without activating it. otherwise, u can find oem keys online for like 10$
AnonymousJon
what's OEM though? I saw most SLS Windows 10 they wrote OEM in, but I'm unsure what it means. If never activate only got the watermark or will there be features blocked?
Haiss seems like need to spend money liao
Ferolare
if you're feeling awfully adventurous, you can go the linux route for dota2
MoneyFace =p
Get product key from taobao like me... Only less than $2. Similar source as those carousell sellers that sell for $10+. Search 'Win10 激活'. Not pirated but also not the most legit channel Microsoft wants you to buy Windows 10. :s13::s13::s13:
AnonymousJon
HAHAHA I don't dare actually
I wanted to but well Dynacore took it over AHAHAHA
AnonymousJon
-FINAL-
Hi, I have finally built my RIG. Apparently can't wait for the sales as MoneyFace recommended as my Alienware officially died :spin:
My RIG Specs will be updated on my profile and surprisingly despite initially I thought i5-7400 was better than i3-8100 but was being shown otherwise to Benchmark. I guess I won't find out which was more suitable for me.
As well as, I said I won't do with AMD.
My final built was probably a different from what I really wanted to have initially.
Many thanks to the following HWZ Hardware Senpai on guiding me through my first built be in through harsh or nice way :s12:
MoneyFace =P /users/461031/
Hailgod /users/613636/
Moderator tmfwy /users/11962/
Ferolare /users/254366/
Elijahonli /users/339406/
Lifeishard /users/542169/
Alienaire /users/515494/
Myzzy1 /users/262294/
Irenicus /users/31795/
Ikkozilla /users/519511/
Shadow84 /users/367144/
AhWei91 /users/242426/
Rashkae /users/172589/
