Recommendations for a Custom / Prebuild Site
Kurojime
Yeah , get a 1440p 180hz ips screen or 4k . No point buy a rtx 4080 but play at a 1080p screen , is like throwing a 3k down the drain
Would the HZ be more worth it or the 1440p / 4K.
Looking at the normal shops now, the price for those tend to be super duper higher than my budget.
Keep finding like 165 HZ 2K or 180 HZ at 1080p and etc
Kurojime
with that kind of specs u wanna go minimum 1440p monitors or 4k. I recommend watching monitors unboxed on youtube for information regarding the best value monitors.
Do i need to look the Hz too?
Cos trying to balance the 1440p/4k and Hz is like killer on my budget
Goodshot
Buy within ur budget lo , actually 120hz also enough . I m still using 60hz . To me color accuracy more important
ragnarok95
Senior Moderator
Senior Moderator
It depend on how much budget are you willing to spend on your monitor. Getting a decent/good one is more important than trying to go for a entry level monitor. A good monitor can last quite long.
You can consider this model from Dell, G2724D. It support Gsync compatible, Freesync premium and adaptive sync. 2K resolution, 165Hz on display port, fast ips panel. All for current price of S$389.
Kurojime
I think is the only one i found so far that is not like $500 or more
ragnarok95
Senior Moderator
Senior Moderator
A good IPS monitor goes for under S$500 now. If S$500 is your budget, then the dell is a much better choice.
Kurojime
Yup. (And originally my budget is like $300 )
Also I been avoiding Amazon and now looking at it. It might be cheaper there
ragnarok95
Senior Moderator
Senior Moderator
Amazon for monitor? Don't bother. Try calling Dell or go down to the Dell stores in Funan and ask if they can do a better pricing for you or not.
soreloser
GIGABYTE M27Q is a decent IPS 1440p monitor. Lazada looks like around $400. Although i would recommend HDR monitors,
ragnarok95
Senior Moderator
Senior Moderator
Then the dell G2724D is a better option than the M27Q.
Kurojime
Ya the Dell G2724D is still cheaper but i will look into M27Q.
Is it cos to many scammers or shipping price?
Like below is some I found.
Courts either too ex or too weak. Sim Lim Dynacore, can't tell cos barely any info that i can see at first glance (I dont want to check every single one. there is a lot lot)
KOORUI 27-inch Gaming Monitor 144Hz QHD(2560 x 1440p) 2K, 1ms, DCI-P3 90% Color Gamut, Adaptive G-Sync, FreeSync Premium, HDMI x 2, DisplayPort, Black ​
$250ish (Amazon)
Acer Nitro 27" WQHD 2560 x 1440 PC Gaming IPS Monitor | AMD FreeSync Premium Up to 180Hz Refresh 0.5ms DCI-P3 95% 1 Display Port 1.2 & 2 HDMI 2.0 XV271U M3bmiiprx,Black​
$260ish (Amazon)
the dell one​
Saw in on shoppe for like $389 to 399
Kurojime
oh GIGABYTE M27Q 27" 170Hz IPS 1440P 2K KVM Gaming Monitor HDR Ready, 1x DisplayPort 1.2, 2x HDMI 2.0, 2x USB 3.0, 1x USB C
Ya was looking at it after u suggest. Shoppee sell at same price as the Dell
ragnarok95
Senior Moderator
Senior Moderator
If you want more connectivity, then the M27Q is better than the dell.
Kurojime
AOC Q27G2S / CQ27G3S | 27" QHD | 1ms | HDR Gaming Monitor for $399
i guessing this not very good.
I really can't tell. I mean I can't even tell which brands are good
Goodshot
Actually $300+ range all the same ba , for me i just pick the most simple and clean like Dell . It just purely do the job for display thats all without too fancy , they had been doing monitor for decades and customer service is good also
