Recommendations for wireless controller for laptop
yongping79
Want to play NBA and FIFA on my laptop, any wireless controller u guys recommend ? Budget $80
SG_Jimmy
Can use on pc ps4 switch xbox
jasonwsc
Xbox One controller with Bluetooth.
Native support for Windows and works wirelessly with Bluetooth.
I won't bother with PS4 controller for PC, not worth the effort to be honest.
xonix
Either ps4 or xbox controller will work fine. Which one will depend on your personal preference.
hafiz116
PS4 joypad for me. Support in windows and Steam is very good now so for those that don't have an XBOX use their PS4 joypad.
Older games yes not great with a PS4 joypad but if your willing to run an application to map buttons (a lot easier than it sounds) then your golden!
Swiftbladez
Xbox one controller if you want to not worry about any compatibility or configuration things.
watzup_ken
Xbox One controller is the best when it comes to compatibility. But depending on the game that one is playing, I feel PS4 controller is still superior. Just that it doesn't work in some cases even when connected directly via USB.
RyoHarusaki
Definitely xbox one with Bluetooth
Unless you prefer usb dongle due to no Bluetooth
Xbox One Controller
or
PS4 Controller
Go Gameshop and hands on and decide yourself.
:s12::s12::s12:
Personally I use 3m Braided microUSB Cable.
Wireless still sucks for me.
watzup_ken
Xbox One Controller
or
PS4 Controller
:s12::s12::s12:
Wireless is always inferior to wired. Its good only for the convenience and tidiness. :o
RyoHarusaki
u sit down on sofa play fifa
with wired controller?
i know wireless got input lag
unless u play online e-sports else lag is negligible
tigerwoods
Logitech PC wireless controller cheap and good
Posted from PCWX using iPhone 1000 Pro Max
