Recommended kitchen sink
Hi, renovation starting soon so am looking for a kitchen sink. Requirements:
1. large, single bowl (>680mm onwards)
2. Stainless steel, though granite maybe acceptable
3. Drop in, but I see mostly SS are under mount
Amazon.sg Has great deals with free shipping for the Kraus sinks and I was about to purchase (under mount model) but saw many reviews saying they’re prone to rust and scratches. Also issues around flow to the drain as the bottom is quite flat. That made me reconsider
anyone has a recommendation to share? Also where you got it from and indicative price? Thanks
I use this. Made in Korea.
American brand
Its the best sink that we have ever used.
https://www.amazon.sg/ZUHNE-Stainle...cphy=9062519&hvtargid=pla-1642267300799&psc=1
i am using Zuhne too. thought this is made in USA.
anyway, yes, this is a good sink. 304 stainless steel and quiet. easy to clean
Yeah my partner was so impressed. Easily the best sink we got and looks good too. Very sleek.
We stayed in a rental condo before we moved and it was by CDL came with supposedly quality finishing and the sink was freaking annoying, with the sharp square angled corners that is the “trend” now. All the food waste would be trapped at the corners so gross.
Zuhne sink is just nice, it’s squarish still looks good and with enough curves for the food waste to move down.
itchying
Hi all
Any advise when buying kitchen sink? Any recomendations? Looking at undermout around 68 length. Thanks
XcoldstarX
I bought quartz composite kitchen sink from Taobao. Will update after receiving and installed.
Windowlover
ANy recommendation for kitchen sink single bowl prefer deep height more than 200mm,,, currently having what nano coating, it is good technology ?
baobei0429
I'm thinking of buying a quartz kitchen sink from taobao too. Would definitely like to hear back your experience buying such a big and heavy item from taobao.
XcoldstarX
My sink arrived safely, and with the dimensions provided to my ID while it was on the way the carpentry was made. It fits perfectly. Will share pics.
baobei0429
+1 to my confidence level buying from taobao then. Did you ask the seller to reinforce the package with wood crate?
XcoldstarX
I used a 3rd party forwarder, they helped me to inspect the goods and crate the packages.
XcoldstarX
Bought this quartz composite sink from Taobao Tmall:
https://detail.tmall.com/item.htm?id=577099744280&spm=a1z09.2.0.0.a5012e8du0rlJY&_u=51n42pk278af
Got my 3rd party forwarder (been using them for about 5 years) to open and inspect the package before crating up and sending to me.
My carpentry was fully up earlier this week and they put in the sink for fitting and measurement, the sink looks really solid:
Killingeve
Can share with me which 3rd party forwarder you use? I am going to purchase a vanity basin and worried about damage during shipment
XcoldstarX
Thank you!
They are pretty awesome so far in the 5 years I have been using their services.
for my current place I even bought an entire vanity set (sink, sink vanity cabinet, mirror cabinet) from Taobao and they helped ship it here safely.
Killingeve
Ya the customer service very responsive and I appreciate they are quite flexible to allow me to store longer in case of any delay. Cos I intend to customize some piece and I not sure if there will be more delay on the seller’s end.
Thanks for the recc!!
Geminispace
How the sink from zuhne so far? Heard about it having surface rust issue which is weird and not sure those are true
savagesg
Hi
how is this Zuhne Oslo V5 Workstation Kitchen Sink?
https:// zuhne.sg/collections/oslo-v5-workstation-kitchen-sink-with-integrated-deck
what kind of mounting is recommend ? under mount maintenance how
