Red Wing shoe Thread
xtreamzz
not sure if this helps
I have a pair of 8165 in size 6D, 875 in size 5.5E.
BUT i feel my 875 more loose, dunno issit coz of the width...
D is wider than E is it?
so i should get 10D or 9.5D? since ur 5.5E is more loose than 6D
d3n
my first wings!
i notice that my shoe does not have the RW logo at the side of the shoe... is this normal for my shoe model?
kazuki666
my first wings!
I also aimed this color de.
But too bad beckman doesnt carry my sizing, i wear a 6 de... :(
mikeeeey
good hoot d3n!
yup there's no logo on the sides on beckman series
the leather beckman using, featherstone, already comes pre-treated.. no need to give it TLC so fast.
i wore mine for like 1 month before applying LP and it already took some time to get absorbed in so i guess it still has the natural oil in it..
d3n
good hoot d3n!
thanks for the tips!
LP is?
mikeeeey
LP is?
Obenauf's Leather Preservatives (LP)
so you got put any insoles with it? i used to put insole in my 9013. now i feel more comfortable wearing it without insoles. lol
d3n
ohh i dun used insole cos i find it comfy enough
ambivalence
guys.. you guys measure your feet size at the rw store in suntec isit?
and eg your feet size is like uk8 ... then for the rw you get uk 8 or uk7?
Studded
^I'm a UK8. When i downsize by half, it's dam tight for me so i went for UK8 instead.
Width D btw :)
Jazzbie
Guys, me noob at RW boots. :p
For 6 inch boots, the size is around the same as our Army boots right? Weight wise also similar?
If so, I think I am better off with Clarks DB cos I find Army boots size a bit too bulky for everyday wear?
d3n
i measure my feet at suntec haha... then go order... never downsize.
my left feet is 6.5 actually while my right feet is 7.
