Nakedtoes
- Dec 9, 2002
Only saw 735 after 80$ discount . Where to get 721?
Sent from Huawei Mate 20x using GAGT
2% discount buying GC
Haha, can compare bro... After reading your explanation, it does make sense too. But that made me realize something about my own purchasing decision...
Like, I realize I always only buy the "Pro" version of phones. So my first thought was also to compare K30 Pro Zoom vs Xiaomi 10 Pro... I've never thought of comparing K30 Pro Zoom to Xiaomi 10, cause never thought of buying non pro versions at all.
Like if can afford it, I always want to go Pro. If can't afford or find bo hua, then I don't upgrade handset... Interesting...
In other news, my set arrived at the "Departure centre".![]()
usually when ppl compare phones they usually compare at same storage and ram since it is configurable unlike the rest of the hardware. but comparing price bracket is also a fair point of comparison.
personally would take k30 pro zoom for basically the cons u listed for the mi 10 and its cheaper. wireless charging isnt that big a deal and generates a lot of heat, and personally cant see the difference between 60 and 90hz screen unless i am told it is a 90hz screen![]()
Maybe because i m a peasant so i m always looking for what i can get for most within a certain price range. happy that it gave u another perspective.
do update if ur toy arrive
really. i thought most would set a price range and see whats the best they can get for it. guess i was wrong.
yes i m torn too.
I dont really care about storage since 128gb or 256 makes no diff.
i guess most of the time its down to preference for certain features when u have a limited budget.
GC can stack with QCoins?
This skin if pasted still can put in tpu case? Will it become too tight?
There's English languageHi all, appreciate some advice with regards to China rom for K30 pro. For China rom, does it mean that the system language can only be set as chinese or english and no other languages? Does this also apply to the keyboard language for messaging?
This only..Hi all, appreciate some advice with regards to China rom for K30 pro. For China rom, does it mean that the system language can only be set as chinese or english and no other languages? Does this also apply to the keyboard language for messaging?
I see, thanks a lot everyone for the very clear explanations. Much appreciated!
Hi everyone, just wanted to check with those using China ROMs, any issues with localising use here? Important functions that I wish to use are Netflix, Google Pay, Maps (have heard GPS issues with China ROMs), and bank apps. I think installing Play Store not an issue as I can install it straight from the Mi App Store.
Hi, for China ROM any issue with local bank APP or NFC. very keen in zoom .... tq
Sent from HUAWEI EVR-L29 using GAGT
Using K20P CN, shouldn't be much diff. Everything should work. No issue with GPS and bank app as long as you don't touch bootloader and custom ROM. Netflix work, but almost all MIUI CN ROM only L3 widevine, even global is rare to find L1.
2020-05-28 Starting Delivery to the Destination Country
Wait until neck long liao leh...
