Redmi K30 Series, Pro and Ultra
icecap
When u all said K30 Racing edition not certified u all meant google pay not certified or the play protection not certified?
Beefsteak
Play protection not certified. But I think it also affects not being able to use google pay or some banking apps.
erniechua
I have no issues with banking apps though... DBS, SC, OCBC, AMEX & Citibank all works fine for me... I just cannot find Google Chrome (this one I get through GetApps) & Google Pay on Play Store... Google Pay Singapore also cannot add cards to account... so it is back to my trusty NETs Flashpay for commuting on public transport, when I need to... haha
I'm fine with everything else working as per normal - Android Auto & Waze for my driving around. =P
frizee
don't know by when will get fix... maybe should just offload :s13:
Well, good luck bro! :)
Hi! Are you on Racing too? :s11:
For me, Banking Apps need to tap on it for the push notification to come up, but, once it's in background, when I log off and login, the push notification comes up. =:p
erniechua
Yup, on racing too. I have not tried to login from desktop and use the phone as digital token so I think I should try... haha... always just use the app to log in without any issue so far...
I dunno whether can send a support ticket to Xiaomi to request they get the Redmi K30 5G Racing certified... =P
Beefsteak
Long tap the app > App info.
Enable auto start and disable battery saver.
You should be able to receive notifications.
frizee
Thanks bro :)
I didn’t apply these setting and SCB works fine. OCBC and DBS are the problem ones lol, I’ve given up already lol!
ranmaru1987
Anyone having problems with funding societies app and axs app? Funding societies can get past 1st page.. axs can't get through load screen..
Sent from Xiaomi REDMI K30 PRO using GAGT
24thchromosome
According to this web page, the Device ID is for you to retrieve the Google Service Framework and copy to Device Registration for your phone to work.
Follow the steps here.... https://www.technobaboy.com/2020/03/07/how-to-fix-device-is-not-play-protect-certified/
Thanks! The steps contained in the webpage is very helpful. But very strange device still not certified even after my google services framework ID has been prompted "value already registered" when I tried to do it a few times. Reboot device still same outcome. Clear cache also makes no difference.
icecap
Also couldn't seem to find this issue faced by others globally - like no one other than here faced the problem and reported it. So strange when Xiaomi and Redmi have so many other phones that have special editions but they are all listed in Google except this Racing edition.
24thchromosome
but thats not the only lte band they using right?
i saw singtel using 3 7 8, so missing 1 i guess is ok?
can rely on 3 and 8.
Pls do let me know how it goes with your k30 under singtel network after you've gotten the device.
If the lack of B7 really not a problem, I'll probably sell off my racing since couldn't get device certified, and then switch plan to one of the MVNO under singtel network.
