Redmi K60 Ultra..
twinbaby
I did not know it was being released.
Anyway, the K60 Ultra is around $500 while the K70 Pro is around $800 for similar specs.
Since it is cheaper, I can upgrade to the next phone faster after 2 years :)
If I were to choose between K60 Ultra and Xiaomi 13T Pro Malaysia set (after all they are about the same) , I rather go with malaysian set. Its about 710 SGD after all the discount.
https://shopee.com.my/New-Arrival-X...05&xptdk=d6c7f36b-d804-40df-a5ed-8e4a00223305
andyhtc
Suspended
I find it strange that the Lianhe Zaobao 联合早报 app cannot launch in the K60 Ultra.
I have to resort to using MS Edge with the pre-loaded website as a favorite to go into the portal.
I would be happy if anyone could share a similar experience or a fix.
ZhuTou!
Can try go permission to see anything can turn on and also the auto start, battery saver thing. It is always these few settings only.
andyhtc
Suspended
I think it is the app that is not optimised for China ROM. Anyway the work around is fine. Thank you.
axe008
I just installed the banks and SingPass apps. No issue so far. The only part that is not so nice is that WhatsApp contacts load a bit slowly, so it takes about 3-4 seconds before the numbers change to names.
Archiving a possible solution here before I try to remedy later.
https://forums.androidcentral.com/threads/contacts-list-and-opening-contacts-very-slow.376834/
Have u solved the above problem? Do you have Whatsapp notification delaying? Battery life? Hot? Still on Miui14?
Hope to hear from u soon. Or anyone able to advise?
andyhtc
Suspended
Yes, it was resolved. The solution is available somewhere in either K60 or 13 Ultra threads.
I didn't notice any delay for WhatsApp. I don't check my WhatsApp often...
I don't feel any difference between the old and new OS. 99% is similar to me.
