Redmi Note 10 series
Teo Ming Ern
Hello, I bought my Note 10 Pro in Oct 2022. Since then there's always an overheating message when I use it for video calls for more than 20 min... my wife's Note20 Ultra can be used for the same video calls for hours... we use mostly WhatsApp or Messenger...
Anyone knows how to overcome this issue? Is it a setting issue?
caterham7
try using without the phone case, to see if it makes a difference
besides that, not much else to try, except perhaps making the call in a aircon environment?
pigpigoink
no idea too, but maybe one thing u want to try is to reset the phone... but that means all data lost and u got to re-setup your phone all over again.
how is the battery life during idle, and if it's warm even when idle?
Teo Ming Ern
Apparently not... just seems like when the GPU is engaged... I mean does the GPU engage during video calls? It's quite a weird situation... not sure if there was some setting that can be done to reduce the throttling... didn't remember reading about the Note 10 Pro throttling leh...
Reset is kind of last resort... too many things to set... takes too much time actually...heh...
Teo Ming Ern
Is this a known issue? Unfortunately aircon environment not a possible use case given that the phone is used outdoors mainly... very weird... yeah will try without phone case and see how... didn't think it would actually affect the CPU temperature...
Sausage
my Redmi note 10 pro battery bloated leow. is it easy to replace the battery? the back plaate already opened a s I can just tear it open. but is the battery cabling complicated to replace?
Read HWZ Forum Rules!
Krabs.
opening difficult part is black paste around the camera block , quite deep inside hard to reach with a plastic sheet to 'saw' it out
only battery plug and fingerprint sensor plug
test bootup first
the hardest part is what you going to glue it back together since the black gum removed
DesilDesil
i have a 10 and same issue. just hooted note 12 for $140+ on 6/6 sale lzd.
Mine also but just a little bump so hard to tell if really is
Do you get random restarts or bootloop?
MisterRei
Xiaomi service center told me that they dont have any replacement part for this old model. (Redmi Note 10 Pro)
So I decided to DIY and ordered a battery from Ali, but no news after waiting two months. (money refunded)
No choice, I took my phone to the repair shop and received a quote of $38 for the battery replacement.
Seeing that they have to do diagnose test (check buttons, screen, microphone, camera and etc), and I can't watch the whole repair process (They had a repair room at the back and took 1~2 hours to repair)
I decided to format my phone, even though I don't have any sensitive photos or videos, I find it annoying to have to delete contacts and log out of banking apps, emails, Singpass, and other apps.
If only Xiaomi have "Maintenance mode"..
Phone is working perfectly now as my secondary phone, just that it gets quite warm when playing games..
MisterRei
So the phone battery was bloated again, this time it would cost $50 to replace the battery. I'm using this phone as a backup phone, now still deciding if I want to repair or buy a new cheaper phone
DesilDesil
Not worth already
Even if it's a new battery
Just by virtue of it sitting on the shelf for 5 years would have degraded in one way or another
