Redmi Note 10 series
Krabs.
Wa **** , my phone something got this twice . this time i cant even power on.
I didnt install anything recently , is it the new update abit off
your post 26 april
now 15 may I encounter the same "cannot boot" problem without any pre-failure symptom
still cannot find any fix , tried the tapping compress method on youtube to push back any loose connector ... cannot work
from google search and youtube , seems like the hardware failure can be more than just battery ... youtube many comments same problem with redmi 1-2 years ago
youtube ppl save money will heat up the cpu or power chip to resolder .... too high skill for me ....
personally i guess battery or motherboard fail due to prolonged video watching @ high brightness & simultaneous charging while inside phone casing trap heat .... cooked to death .... or accumulated drop damage
from plugging in a slow charger for hour+ can feel slight warmth at the top electronics area above the cool battery area
Severon
your post 26 april
if buy replacement battery , $14 aliexpress slower , $19 sh0p33 boleh faster
still have to think about eventual replacement phone $300+ budget
will get the $14 aliexp battery to attempt recovery weeks later , just moved over to temporary phone
Gg bro, honestly considering the cost to replace it. Its better to get a new one, although i am suspecting its one of the motherboard chip. Well its the last phone i have with a headphone jack lols
carboy00
your post 26 april
not Redmi Note 10 Pro but my Poco F2 Pro suddenly turned off by itself and cannot boot up again, brought phone to shop to repair and they said it is CPU failure, they say is a common issue with Xiaomi, they fixed but warn is a temporary fix, I went ahead since I had to get my data out.
Read HWZ Forum Rules on realme GT2 Pro
luei74
Can check how much they charge to replace the board?
a4973
Can share what is the fix? Thanks
tian_yibang
Thats why its been said many times alr
Tiong cheap fones in particular (or any other fones in general) u must regularly do backups
cos they can just suddenly mati w/o notice
Remember
its cheap for a reason
anyway
just nice today 19 May exactly 3 yrs the fone first released/launched
At least your fone mati almost to the 3-yr mark
Krabs.
the replacement battery didn't help , still no response when plugin 3 different charger
used USB device to measure it drawing 0.2 to 0.22 amp x 5.28volt = about 1.1 watt ... it's slightly warm at the middle part beside camera lens ... same as before disassembly
didn't plug back the fingerprint cable and mid-frame though ... don't think need to screw back to charge
tmr screw back everything and try charging again , likely won't work ...... so it's cpu or motherboard failure
alex22
Anyone see this in miui14 before?
I can only search it in the menu search box but cannot navigate around to reach tis.
Rmn10p and poco x4pro both
How to disable?
pigpigoink
Search in the settings search box for "acceleration"
redmi note 10 4G 14.0.8 software version, search 'acceleration. Can see
-tethering HW acceleration
-smart multinetwork acceleration
under 'smart multinetwork acceleration', can see 'use mobile data to boost speed' option.
