Redmi Note 10 series
xtractor
just received today
No EIN sticker though
dono this one consider direct factory sealed or what
but im don't really care as long i already got the phone super happy liao
comparison with Redmi note 7 Pro
there is square box on the centre of the display
no idea what is that i thought it was my tempered glass but not from it
installed new privacy tempered glass
and found it out after using ultraviolet light
xtractor
anyone found waterproof case for this model yet?
tried to use note 7 pro waterproof case does not fit
wizardundo
No EIN sticker on my set as well, there is the same rectangle on my screen UV light.
The phone default is 60hz, need to manually change to 120hz (in Setting -> Display -> refresh rate) [So smooth...]
If you want to turn off the vibrate on touch. (Touch feedback) [Settings -> Additional Settings ->Accessibility -> 'Physical'-> Vibration & haptic strength-> Touch feedback Off]
Seems like I have trouble moving (Mi Mover) my old call logs and SMS record as the new phone uses google dailer / google messaging. I read about a work-around by requires Mi cloud sync. Guess I'll have to do some tweaking during the weekend.
https://c.mi.com/thread-2921820-1-0.html
hg2
Tracetogether error "Your app is not working".... just hang there not matter how i tap the allow button...
The app was working fine yesterday and today morning... until miui12 (12.0.12) camera update this afternoon.
Reinstall tracetogether also did not help.... looks like a show stopper... switch back to old phone.
kottty
Tracetogether error "Your app is not working".... after miui12 camera update this afternoon.
The app was working fine yesterday and today morning... until the updates...
oh no..Heng i haven't update yet..thanks for let us know..update us again if it working again.
stillgottheblues
Tracetogether error "Your app is not working".... after miui12 (12.0.12) camera update this afternoon.
How can this be? Must be the app having problem.
hawkwind
The Tracetogether problem can be solved by as follows:
  • Settings > Advanced Settings > Battery manager > Power plan is set to Performance
  • Device Settings > Advanced Settings > Battery Manager > Protected apps – your app needs to be Protected
  • Device Settings > Apps > your app > Battery > Power-intensive prompt and Keep running after screen off
  • Settings > Additional Settings > Battery & Performance > Manage apps’ battery usageand here:
    1. Switch Power Saving Modes to Off
    2. Choose the next options: Saving Power in The Background > Choose apps > select your app > Background Settings > No restrictions
  • Security > Battery > App Battery Saver > your app > No restriction
kottty
sorry to ask .r u using redmi note 10 Pro? there is no advance setting and device setting
hawkwind
Using RN but should be the same. The instructions are from TT support staff but not exactly for the Redmi menu but the idea is to toggle battery saving for TT app to "No Restrictions". Worked.
xtractor
  • Go to Settings​
  • Battery & performance​
  • Scroll down and Choose apps "Tracetogether"​
  • Go to Details and find Battery Saver set “No restrictions”​
kottty
easiest way just press and hold the APP at homescreen.den select APP info..
but now mine is select MIUI battery saver no issue wor
