Redmi Note 10 series
matrix05
Wow, N10pro finally available 3mth after launch. Btw anyway reuse /connect old phone, thru a docking station or app, to a big screen and mouse for surfing, media?
SkyShroud
drop my phone and the gorilla glass crack
new tempered glass just replaced after the glass crack
accident happened when the phone slip out of my hand while looking for my keys
drop right at the egde of the phone then hit on the road divider :s22:
advice to anyone to buy good tempered glass which cover the whole phone
Was quote $120 to replace the screen but i will leave it that way
not so obvious when the phone turned on
but can see the hairline crack mark when the phone is off thats all
Look like bad casing to me
The screen including tempered glass seem protruding out of the casing
if that is so, the tempered glass will absorb the impact instead if fall face on and not the casing
the impact then will transfer to the real screen itself
im using similar casing like this, all my phones use this casing similar design
https://shopee.sg/-Ready-Stock-Sams...roof-Rugged-Case-Cover-i.321833243.5761944520
the edges of the casing around the screen is deliberately made higher to absorb some impact if fall face down
the back plastic strengthen the TPU, TPU itself is soft so yea...
soft means ur impact transfer to your phone so the back plastic absorb some of it
i1magic
This case, I also bought before. The only downside is that it will make phone thicker and more bulky.
SkyShroud
yep, that the cost of protection
i dropped a couple of times and no noticeable damage to all my phones
now i dont even use tempered glass, dont see the point, instead i use old school hydrogel
ZhuTou!
Old sch is screen protector flim
Not hydrogel lol
ZhuTou!
Bodyguardz cover whole phone include rear
I think the texture is diff also
Hydrogel cover screen only and its abit rubbery feel
i1magic
Yah. Basically balanced.
Tempered glass SP saved me quite a few times, so I will still use that. Plus I like matte screen, so need to use tempered glass SP to achieve that.
8-lane
Does anybody know whether the back of the glacier blue RMN10P is glossy/shiny or matt/frosted?
tckrto
Do u know that for xiaomi there's no way to use cable video out to monitor or screen? There's no HML support. Xiaomi using cheap USB 2.0 only. However u can use wireless display to cast your screen but got some lag.
i1magic
After using RMN10P for awhile, I think I still prefers fingerprint sensor at the back.
How about your all?
