Redmi Note 11 series
aljj1996
Dimensity is not bad la
Dun keep sticking with the old gen mtk mindset
Like old ppl like that, mindset never change
Machiam the war btw intel vs amd
Tech will upgrade and improve over time
Altho there are not much redmi 10x user here but most will tell u their phone is ok and satisfied with their phone
I use 1+yr liao never give me problem, not even hot like the old gen mtk
Last time all siam china product
Now all use china product
Things will change
My bro oso use redmi 10x he say not bad. If not for the sudden gms not working he wouldnt change
amazingone
MTK has improved a lot with their Dimensity SoC series, making it on par with the likes of Snapdragon 7-series with their Dimensity 1000-series. Maybe one day they will have a Dimensity SoC that will be on par with the top-tier latest Snapdragon 8-series.
cosycatus
almost like the note 10 series.
I think the vanilla note 11 is the most value for money, 200 plus SGD got 90ghz amoled screen liao
007Mi6
What is the difference between the 11 Pro and 11 Pro plus apart from the charging speed and battery size?
amazingone
Redmi is heavily promoting the Note 11 Pro series, feels bad for the vanilla Note 11 but it should help in boosting Xiaomi's sale result for the upcoming 11.11 sale.
Ctrl_Alt_Del
Review with comparison with note 10 pro/poco x3 gt. Both about same gaming performance after thermal throttled.
Teardown of note 11pro+. 3 choose 2 sim tray support either dual sim or microsd
AM investor
Dimensity 1000 is comparable to sd778?
AM investor
The review video above got compare dimensity 920 with honor 50 pro(sd 778g) at 7:12 timing, 2fps higher average fps but about same after thermal throttled, sd 778g slightly cooler.
I see, dimensity 1000 should be better than 929 right
