NightRaven49
- May 17, 2019
local set gps should be ok. my mum's rn7 is china set, no gps complaints from her and she drive grab quite a bit also.
Saw the the awaited realme 3 pro selling in redwhite mobile riaos, $319 after their cash discount seems great Sia... Hab the SD710, 128/6GB ram.
You comparing with variant ? N7 or N7 Pro ?
N7 Pro has comparable hardware, better in my opinion. Micro USB on realme3 pro is kind of a disgrace in 2019.
N7 pro have local sets?
Realme 3 pro at $319 hab 2 years local warranty lei....
Do RN7 have global ROM?
Was thinking if replacing my RN4 which current unable to charge
Anyone know why is there different warranty of 12 months and 18 months local warranty?
I bought on lazada from Global Tech, 128gb local set with 12 months local warranty. I see some other sellers like xiaomi certified and univercell on lazada provide 18 months warranty. Is global tech legit?
Anyone know this strange issue? I'm trying to sync google contact from my dad's old Samsung phone to the new Note 7 thru google contacts. Samsung got 450 contacts sync with google, went to google via computer and see that it has 450 contacts too, but Note 7 sync only shows around 227 contacts. I tried re-syncing, tried rebooting the phone and restarting the contacts, but still can't fully sync.
450 is just Google contacts450 is combined total ? Google, phone and sim card ?
Where to get the local RMN7 Pro? And is the performance difference obvious between non-pro and pro version? I checked a regular online shop like RWMobile, HiTec, etc they only have RMN7. Thank you.
no such thing as local rn7p, as it is china and india exclusive. if u buy from online then it is definitely export set with either indian or china rom.
sd675 is definitely faster than sd660, on sd835 level cpu wise. personally believe 48mp is a gimmick, so it is only a slight sensor upgrade as the 586 has a better track record with other flagships. apart from that not much difference, since u are getting the same design, same screen, same battery.
