Redmi Note 7
Sausage
Does anyone know how to check the warranty of this? The website asks to scratch away some silver panel on the box to reveal a 20 digit serial number but my box doesn't have a silver panel. Bought from Global Tech on lazada.
bbcccc
10.3.10 global rom is out . . .
Sent from Xiaomi REDMI NOTE 7 using GAGT
hlw8888
juz realised that redmi note7 pro LTE-A is Cat9 while redmi note 7 LTE-A is Cat12. i thought note 7 pro newer chipset so shld be faster instead?
i am thinking between note 7 and note 7 pro to replace my current redmi note 4.
NightRaven49
both use the same x12 modem, which also happens to be the same on the sd820/1 on flagships from 2016. the 675 has a significantly better cpu performance though, considering the 660 is a one year old chipset.
personally feel the rn7 is still better in terms of value. if ur not doing anything intensive it should be good enough to handle day to day use quite snappily.
hlw8888
btw, is it easy to install GCam (google cam) on redmi note 7 ah? thks.
Teo Ming Ern
Anyone knows where I can get a list of languages supported in the Redmi 7 Global ROM? I need the phone to have Khmer language. Anyone using the phone can help me check? Not sure if Redmi Note 7 and Redmi 7 ROM same or not, but I think may be related so I asked here. There isn't a dedicated Redmi 7 thread unfortunately. Thanks!
Teo Ming Ern
Answer my own question... went to Mi Store at JEM... the Redmi 7 has Khmer in the Global ROM... MIUI 10.3.1.0.
Aizenhart
For the Redmi note 7 pro China version, is it only available in the 6GB + 128GB model?
Am asking as I saw a 6GB + 64GB model selling on taobao.
NightRaven49
I've only ever seen 6/128 rn7p on taobao and the official china mi site. u sure u looking at pro version? some shops sometimes sell both pro and non pro under same listing.
Aizenhart
Thanks, then I guess it might be a non pro version of the phone.
Extech
