Redmi Note 7
Jurong640
The Redmi Note 7 Pro will not be available globally
Xiaomi's Regional Director for Southeast Asia John Chen, who said it’s not happening. The Pro will remain exclusive to China and India due to Redmi’s product strategy.
Seems like it's true for now, no pro version
Hello everyone, want to check if it is safe to get those global rom Redmi Note 7 on Shopee / Lazada? So the bootloader would have been unlocked for us? A bit noob at this. But now looking to get the $289, 4/64 version.
xonix
The bootloader is not unlocked, you will have to do it yourself. The tricky part will be determining the seller is providing actual global ROM or China ROM flashed with Google play services.
UO
The bootloader is not unlocked, you will have to do it yourself. The tricky part is the seller is providing actual global ROM or China ROM flashed with Google play services.
Does it matter if u just assume it is China ROM and you try to flash it to global? :(
kazuki666
Will the pro be available as export sets w global rom?
India ROM should be better pick than China's for us? But then again how we know what we buying are India set... Hahah
Sent from Xiaomi REDMI NOTE 4 using GAGT
tang_tang
At first i hv the same thinking as you to get the Redmi Note 7 export set. But worry is not global rom and having the gps issues and ownself might not able to solve the problems. So i just settle with a pocophone with a more peaceful mind since Note 7 pro wun be coming with global rom.
tomsss
Not sure why kind of gps issue. I bought a China Redmi Note 7 for my dad and no problem with GPS
Maybe only certain batches. What happens is that it initially captures your location, but it doesn't move along with you as you move about. You had to turn off and on the GPS to update your location.
tomsss
Qoo10 Finer vendor selling Note 7 Pro 6gb+128gb for only $354 :s22:
Dammit, if only I had the patience to wait lol
