Redmi Note 7
tomsss
Anyone here using BT headset or earphones kenna this stupid problem , while phone in pocket and you are walking, the Spotify music playing gets random speedups and interrupts due to the sensor at the phone earphone area? Even turning off or on the Pocket Mode doesn't always work, and when you get the message about not covering the earphone area, press volume up button to turn that feature off, then the issue goes away..... but still comes back later
Dunno if its the proximity sensor or light sensor causing this... but I feel its software issue
lewissac
Seems like not a bad grab but if me I would pay abt slightly $50 extra get the 18mnths local warranty set.
Agreed. To me actually not just the 18 mths local warranty, but goes a long way. It's the subsequent repair. To my knowledge, export set are not allowed to get it repaired in their authorized store. Correct me if Im wrong.
matrix05
Bro can tell where is the ah bing store I want to go down to see the phone. In terms of specs so far multiple review shows 710 slight edge in mixed used cases.
But the quality build and cam does worries me though multiple reviews said the details from 3 pro is better than 7 pro, but from pic sample still find 7 to better.
Lastly is MIUI vs flyme
Its realme3 thats available (not R3pro).
ahwei91
Any way to check if the empire qoo10 note 7 is a local set? Will get it if it's really local one
their samsung phones anyhow price one...
A10 local set = $300 (local price $169)
A30 export set = $410 (local set less than $300)
A50 128gb export set = $530 (other ppl selling $3xx)
this shop so weird..
kazuki666
https://www.facebook.com/235370653223663/posts/2204693822957993/
Why would one be silly to buy from Mi Singapore? I don't get it
Sent from Xiaomi POCOPHONE F1 using GAGT
boo
any1 facing problem of paint peels off at side of redmi note 7
just bought the phone and used it for less than 2hrs and paint coating at side of the phone peels off. any1 face the same problem? service centre refuse to fix as it was not a reported defect!
redname
any gd quality transparent/translucent cover to recommend?
by gd quality i mean the cover is tight
