Redmi Note 7
amazingone
Then the older SoC phone will drop price. If the SoC performance difference is not much , may be better to get the older SoC phone.
Sent from Xiaomi REDMI NOTE 5 on Rocket Uno with TPG Booster using GAGT
Performance wouldn't differ much, the SD660 and SD675 are still powerful today.
Redmi is likely to choose either Snapdragon 665 or 730 if they decide to intro an incremental upgrade for Note 7.
Broadwalk
Same goes for note 7 pro?:o
boo
hi boo,where did you bought your set? Did u saw the peel when u unboxed?
bought from m1, checked when first opened and looked ok. the side finishing paint came out after a while. if have a few cases, they will not be able to deny it's a defect.
if dropped or scratched, will not be a patch that came off
boo
Warranty normally won't cover comestic damage.
yes they said was cosmetic defect.
but if dropped or scratched, will not be a patch that came off
tomb
https://xiaomireview.com/redmi-avengers-end-game-limited-edition-collectors-phone/
kleinkoh
Information for those who going to buy anything in Malaysia.
https://mustsharenews.com/gst-relief-singapore/
Aaagogo
isn't the incremental upgrade the redmi note 7 pro?
It's rumoured that Redmi Note 7 may see an incremental upgrade this year, with one of the recently-announced Snapdragon 6xx series SoC. :o
Audiology93
If 2 person going, 1 take phone 1 take box. If not just throw away the box and keep the accessories. No point paying the GST just to keep the box :s13:
Even the 670 is good enough if the price remain the same range as current price.
Sent from HUAWEI Mate 20 using GAGT
kazuki666
Just curious. I am currently using a brand new 64gb Poco F1. What will be the biggest pro and con if switch to a 128gb RMN7??? :p
Memory aside of course. :D
Can't see notification is one problem for me. I keep having to pull down screen to check which makes me like a phone addict... lol
Sent from Xiaomi POCOPHONE F1 using GAGT
Ultimo_Urien
No play graphics extensive games will be ok, jus like I prefer mi8 lite design over my Poco F1 armour edition.
Nakedtoes
Can use apps to show nortification on top.. Pls go and search.. U downgrade to note 7 u confirm regret.. Not only cpu slower u get slower memory inside phone...
For nortification u can try notch test..
kazuki666
I was trying notch test apk. It does notifications diligently without pulling down. But I notice if I pull down (didn't swipe away), the notification will not appear on the top corner anymore. If I pull down, still can see down. Not sure if it's my settings wrongly. Maybe go play with it tonight
Nakedtoes
Mine pull down still show.. Unless I swip to remove
EveMuffins
Sorry noob question.
My OTG thumb drive is micro usb but Note 7 is type C usb. How to use the thumb drive in this case?
PeasantBeing
Buy adapter.
Some time ago I bought several types from eBay. Normal USB to micro USB, normal USB to type c, micro USB to type c.
Yuripa
Use type C otg thumb drive instead, its less of a hassle as compared to micro usb otg thumb drive + micro usb to type C convertor.
