Redmi Note 7
JLowX13
Hi. so anyone bought in Singapore and can share a simple review on it? worth the current price tag? Thank you.
Nakedtoes
The review compare with pocophone camera... So note 7 is interpolate to 48megapixel..
davidwong
But according one of the reply in the earlier question that for the pro variant using the 675 cpu will not be able to output to true 48mp
Yea, hopefully the pro variant with sony sensor and better processor will support true 48MP.
chaiscool
When you compare prizing you need to put in percentage perspective
284 to 368, about 29% diff. Pro would be even lesser. The difference in number depend on users as some may consider cpu and ufs to be worth the extra cost.
yusoffb01
Redmi note 5 pro camera performs better than fake 48 megapixel note 7
matrix05
Xiaomi is yet to reveal the exact launch date of the Redmi Note 7 but we believe the smartphone could be launching in the first half of February or maybe if only the company can pull it off there could be a January end launch.
=== cut & paste from India newspaper.
Global rom (with playstore) for Note7 should be available 3 weeks from now. So hold your horses, unless urgent need.
davidwong
Seems the chinese really like the note 7 for the budget and design and value and mi8 voted for best mid range
In sg what the current price percentage diff for note 7 and mi 8?
matrix05
Mi8 is pocco phone price. They are 2x of N7.
windwaver
MiMax2 is SD 625 and has lots of bezels. Your mum will not be able to play pubg well and look old fashion.
lol, if playing pubg is a requirement, a larger battery is even better.
However, I see most older folks play pokemon instead of pubg.
Ultimo_Urien
I think for people who need jus play game den Poco 1 sits jus fine, no need get other phones riaos..but those who need a premium glass and metal feel den it's mix2S, Mi8 or the cheaper upcoming note 7 or current Mi8 lite.
davidwong
Then Bro,
How about the cheapest phone with nfc and no lag or stuttering in surfing and scrolling FB? And good cam?
Ultimo_Urien
Then Bro,
Last time someone mentioned Samsung A8 star, promo time $399. Good batt life and cam with NFC, same SD660 cpu as coming redmi note 7.
Nao maybe have used sets on market at $300+?:s11:
