Redmi Note 8
GoodBetterBest
Install 11.0.2 or 11.0.4 on Android 10 will resolve it.
Looks like it's not the update that solves the problem but the process of updating that initially caused and later solved the problem. I conclude this because when I hard reset, it also solves the problem.
bbcccc
yup, I hv to reset my phone after the update to hv the nfc working again
Sent from Xiaomi MI-4C using GAGT
convex
Got an export set for Redmi Note 8 Pro a few days ago.
The MIUI version is 11.0.7.0 (PGGMIXM).
Android version is 9 PPR1.180610.011.
Can't set NFC working even though I've used the HCE wallet etc.
Do I really need to do a hard reset?
Thanks in advance.
GoodBetterBest
Thanks in advance.
Turn on NFC and touch a ezlink card. Got response ? If have, then hardware working.
tanchoo1
Thanks in advance.
Try upgrading to Android 10 and see if that helps.
Pocoyoz
note 8 pro use G90T
Note 9 pro use SD720G
Slower, but more well rounded n energy efficient
Sent from Xiaomi REDMI NOTE 9S using GAGT
https://www.gsmarena.com/xiaomi_redmi_note_9_pro_(max)-review-2124p4.php
all Gsmarena benchmarks show 9 pro faster than 8 pro.
Sent from Amazon using GAGT
convex
I downloaded the Android 10 update (Ard 2 Gb) but the system updater cannot verify update (package) and states that the Rom secure patch version is lower.
Any suggestions?
Thanks.
value0230
Anyone experienced very hot phone recently? I woke up and find my phone very hot (not due to charging). Not sure if it is due to video hardware acceleration (supposedly if I forgot to turn off the VLC player) or due to the alarm.
tanchoo1
Any suggestions?
Thanks.
The OTA update isn't working for you?
tanchoo1
Why not just close all apps before you sleep?
convex
When I update, it says no updates were found.
I tried to download the latest update via the ... option on top right. It says "can't download update" and "wait a minute or two to try again".
m/mink
Thanks in advance.
Same here, I got a CN version for my helper.
I wanted to add a Youtrip card to the NFC for groceries shopping. I managed to add the card but it doesn't work when making payment.
tanchoo1
Did you try downloading from here?
https://mirom.ezbox.idv.tw/en/phone/begonia/
Keep tapping the Miui number until "additional features are on". Then select "Choose update package".
