Redmi Note 8
convex
Anyone has changed the battery in their N8P with no issues? If so, can tell me how much it costs and the name of the shop that did the replacement. Thanks
foxer77
normally for xiaomi phone can use 2 year already worth it... i usually change after 2 year ....dont even repair ...
xiaomi phone are use and throw to me....
xtractor
replaced battery myself not difficult also for those who used to diy thing
if u want recommend u repair shop at SLS 2nd floor right after the escalator
around $30-40
repair my ipad and htc there price wise not over hundred dollar
convex
around $30-40
Where to buy the new battery for DIY? thanks.
xtractor
shopee
battery with tools
https://shopee.sg/BSS-Redmi-Note-6-...ent-Sparepart-4000-mAh-i.182872634.6612050053
adhesive glue for battery or can use double side tape
https://www.aliexpress.com/item/100...earchweb0_0,searchweb201602_,searchweb201603_
plastic card for prying open back cover or use playing card
1.use hairdryer if no heat gun
nirV4N4
Yes I had to flash global rom again to fix the boot loop.
The only way to make Google Pay work at that time was to install a custom recovery TWRP & use Magisk to hide the bootloader unlock status from Google Pay.
My phone got hard bricked in the end. It won't turn on or enter fastboot mode. :(
Finally managed to unbrick my Redmi note 8 pro using the method below.
biting
For the past 2 days, my redmi note 8 pro keep rebooting by itself. Any idea how to solve this problem? I tried updating the software but the problem still did not go away. Previously i have never encountered this problem with other xiaomi phones
Pocoyoz
I only charged once. the charger got problem?
Sent from Pocoyo Fan Club
1-wind
Anyone experiencing the same issue as me?
Redmi Note 8
MIUI Global 12.0.6
Limitless Theme and Icons
Gmail, Google Drive, Google Photos app icons still on the old app icons despite with the most updated app versions. Only Classic Theme can show the updated app icons properly.
ThinkMe
CPU: Mediatek G85 (12nm)
OS: Android 11, MIUI 12.5
Bluetooth: 5.2
Memory: 3/64GB, 4/64GB, 4/128GB
No 4k30fps recording
ah_cleo
anyone experience while charging show 70% and can go up but the moment unplug, phone reboot and keep bootloop.. only way is plug in permanently.
tingsters
look like a battery or board issue..
need to get it check..
GoodBetterBest
I'm on last update dated Apr 1, 2022. MIUI Global 12.5.8. Anyone notice it drains the battery after update ?
ekardo
look like a faulty battery coming..
u may want to change the battery..
dun think so, I think it might be the dual sim card causing the issue, cos I turn one of my line off, the battery seems to last longer...but no such issue in the past..
